BAD vibtation under load - JeepForum.com
post #1 of 26 Old 12-22-2010, 07:41 PM Thread Starter
fatkid1983
1982 CJ7
Here's the scoop, 1982 cj7 sbc turbo 350 dana 300 stock front and rear. When I take the jeep for a cruise I get a alot of vibe on acceleration and on deacceleration but if I shift it into neutral it goes away. Any help please as it has stumped me.
Nothing in this truck is worth your life!
fatkid1983 is offline
post #2 of 26 Old 12-22-2010, 11:23 PM
Trapshooter
Have you checked you driveline u-joints?
Did this situation just start or has this been getting progressively worst over time?
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #3 of 26 Old 12-22-2010, 11:53 PM
ASteve
1972 CJ5
X2...that is the first thing I would check...Driveline U-Joints...
Any time I get that type of vibration it's always one of my U-Joints...
SC
ASteve is offline
post #4 of 26 Old 12-23-2010, 01:27 AM
Cutlass327
1978 CJ5
Seeing the SBC and such - did it just start? Are your angles and such ok? If it just started out of the blue, u-joints. If it has been there for a while, it may be a lift or something has messed up your drive line angles..
Rick
Cutlass327 is offline
post #5 of 26 Old 12-24-2010, 01:57 AM Thread Starter
fatkid1983
1982 CJ7
Not sure if its a new prob, been doing since I bought it. Ill check ujoints thanks
post #6 of 26 Old 12-24-2010, 02:14 AM
kakai81
If changing the u-joints doesn't help, check your driveshaft angles.
kakai81 is offline
post #7 of 26 Old 12-24-2010, 11:38 AM
gojeepin
1983 CJ7
I see that your profile lists it as SOA. Is your spring allowing axle wrap? That will put the driveline angle out of whack under load.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #8 of 26 Old 12-24-2010, 01:05 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
I'm just not seeing any entries for 'vibtation' in the FSM. This is a new one!
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #9 of 26 Old 12-24-2010, 02:08 PM
80cj
80cj's Avatar
1980 CJ5
vibration, vibtation, I think we all know what he means. I have a bad habit of clicking on the "submit reply" button before prof reading myself.
80cj is offline
post #10 of 26 Old 12-24-2010, 03:27 PM Thread Starter
fatkid1983
1982 CJ7
Sorry about the incorrect spelling. We call that fat finger syndrome
post #11 of 26 Old 12-24-2010, 04:08 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Just being funny My posts are full of typos.
Ken4444 is offline
post #12 of 26 Old 12-24-2010, 04:23 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Maybe you could post some pics of the rear driveline anlges.. try to shoot the photos from the side so it shows how much angle is in the rear driveline.. both upper and lower part of shaft/yokes.. this would help to point out any obvious angularity problems.
BESRK is offline
post #13 of 26 Old 12-24-2010, 09:26 PM Thread Starter
fatkid1983
1982 CJ7
Not sure how to post pics yet ill try
post #14 of 26 Old 12-25-2010, 12:02 AM
gojeepin
1983 CJ7
It sounds like axle wrap to me... tipping the pinion up then down.
gojeepin is offline
post #15 of 26 Old 12-25-2010, 01:02 AM Thread Starter
fatkid1983
1982 CJ7
How do I fix the axle wrap
84 CJ7 Sputtering Under Load TOBYWON Jeep CJ Forum 2 09-03-2010 04:14 PM
cj v8 dies under load cj5-304 Jeep CJ Forum 15 08-16-2010 10:15 AM
4.2L missing under load Mongoose87 Jeep CJ Forum 1 03-05-2009 03:00 PM
304 runs bad under load aggie.cj5.304 Jeep CJ Forum 1 03-06-2006 12:05 PM
"standard Load" vs "C" load tires on CJ only in a jeep cj Jeep CJ Forum 1 02-19-2003 11:47 AM
