bad starter solenoid? - JeepForum.com
post #1 of 3 Old 02-29-2012, 12:29 AM Thread Starter
Outnumbered
Test run today went well but at end of day I went to shut it off and it kept running. First time it has happened. I have the resistor wire AND diode with stripe facing alternator. Had been started and shut off many times since I rewired alt and installed new starter switch. Anyway, started probing and found 12.6 v at I terminal on solenoid with key off and solenoid hums when battery is connected and key off. Pretty sure solenoid went bad but wonder if any other things to check. Thanks.
1985 CJ7, 258, TF999, D300, D30, AMC20, 4.5" lift, 33" BFG's
Outnumbered is offline
post #2 of 3 Old 02-29-2012, 01:11 AM Thread Starter
Outnumbered
What is the best brand to buy? I need the 5 terminal one for the auto.
post #3 of 3 Old 02-29-2012, 08:12 AM
csabens
They're pretty cheap, I don't know if one is better than the other. Hell they're all made in Taiwan or somewhere besides where they should be. You're looking at about $21 at Advance Auto, they charge extra for that extra AT fitting, it cost me $10 for mine (manual).
Daily Driven: 1985 CJ7 Renegade, 258ci 4.2L (TeamRushed and Nuttered), T176/Dana 300 (in need of an overhaul), Weber 38 DGES, Ion Alloy 174 15x8, MasterCraft Courser MT 33x12.5x15, Front Axle Dana 30 w/ Superwinch Hubs, Rear Axle AMC 20 w/ one piece Alloy USA.
csabens is offline
ignition switch or starter relay/solenoid or starter gone south? jimdubose Jeep CJ Forum 19 01-06-2014 04:35 PM
Starter or Solenoid OrangeCJ Jeep CJ Forum 10 11-24-2009 06:06 PM
Starter or Solenoid? tony dz Jeep CJ Forum 4 10-07-2007 07:14 PM
starter or solenoid northcoast Jeep CJ Forum 5 07-05-2005 08:53 AM
Do ya think it is the starter solenoid? Jeep84CJ7 Jeep CJ Forum 5 11-05-2003 08:17 PM
