Bad Power Valve in the Motorcraft?? - JeepForum.com
post #1 of 3 Old 04-05-2010, 09:54 PM Thread Starter
CJ8Extreme
1983 CJ7
Ok, some background infor first: 1983 CJ7 with a motorcraft 2100 and Nutter Bypass. The carb has been on for about 6 months now and has always ran great no matter what. I noticed a month ago my gas mileage going down but thought nothing of it. Last weekend I began to get problems with it flooding after the jeep was hot. If I would shut the jeep off and let it sit for 15 or 20 minutes it would smell like gas and essentially flood itself while not running. This also made for a very hard start condition as well. Again this only happened after running it and getting it hot. So I kept playing with it and testing things on the jeep.
Today the issue got progressively worse and now the jeep is flooding itself at idle. I just put new jets in so I know that it should not be flooding on idle. I have black smoke out of the exhaust and a very rough idle to say the least. The float level is correct for my setup and the jets are #48. My best guess is the power valve has gone bad and now it is letting excess fuel into the intake causing an extreme rich condition, but I wanted to run this by the people here to see what they thought. I am open to suggestions on testing the problem etc. Thanks for any help!!
Oh and I have a new power valve coming in hopefully by Friday and there are no vac leaks, gas leaks etc that I have found anywhere. That was the first thing I began looking for. My timing is also right at 9 BTC as well
CJ8Extreme is offline
post #2 of 3 Old 04-05-2010, 11:21 PM
VACJ7
VACJ7's Avatar
Sounds like the PV. If you turn the mixture screws all the way in and seat them lightly at idle and it still runs, it's getting gas from somewhere and that is likely the PV. Could also be a stuck float needle or dirt not letting it close.
VACJ7 is offline
post #3 of 3 Old 04-06-2010, 04:38 AM
colojeepguy
1970 CJ5
Take the little cover off the power valve (on the bottom of the float bowl). If there's any fuel in there your pv is bad.
colojeepguy is offline
MC2100 power valve kavephish Jeep CJ Forum 9 06-12-2009 09:16 AM
Power valve block off motorcraft 2100 for extreme rockcrawling Axlesnap Jeep CJ Forum 2 03-20-2009 10:21 AM
Power Valve ?'s derrick7mm Jeep CJ Forum 4 01-26-2009 04:45 PM
changing from gm points dist to motorcraft, motorcraft has wrong gear help!!! baystrucksalvag Jeep CJ Forum 3 07-23-2008 07:55 PM
Power Valve Fropleyqk Jeep CJ Forum 16 02-24-2007 06:56 PM
