Bad Oil Leak From PVC Valve and Breather - JeepForum.com
post #1 of 1 Old 06-30-2008, 06:55 PM Thread Starter
KensCJ7
1980 CJ-7 with a 304 straight six with high miles. It runs great but I have a lot of oil comming out of the PVC valve and breather on top of the plastic valve cover. I'm loosing a quart every couple of days when I drive it. Someone said it may be blow by from a warn engine. What can I do to fix it? I replaced the valve cover gasket and cleaned the engine. And a day later there is so much oil all over the place! Should I re-do the rings and valves, total rebuild or is there a different valve cover I could try? Help.
KensCJ7 is offline
Should I relocate this valve cover breather tube? Rocket6R Jeep CJ Forum 8 11-07-2009 11:44 PM
Oil leaking from Valve Cover Breather *Thunder Jeep CJ Forum 1 05-25-2009 07:03 AM
Valve Cover Breather aqsport196 Jeep CJ Forum 5 04-17-2009 10:13 AM
Edelbrock Valve Cover Breather?? CJ83 Jeep CJ Forum 2 05-29-2008 07:24 PM
CJ-5 Break proportioning valve leak amos_pentagram Jeep CJ Forum 2 09-21-2006 08:55 AM
