Bad Juju with fuel pumps...Now I'M having fuel issues - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Bad Juju with fuel pumps...Now I'M having fuel issues
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 04-15-2012, 06:01 PM   #46
Skerr
Yep... easy rebuild. You said it sat for awhile? Gas varnished up the jets maybe? Piece of trash in the jets? No sweat. The rebuild kit does a couple different models, so you'll have parts left over. I have the NAPA part number in my shop if you need it.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 04-15-2012, 07:03 PM   #47
Gido
1980 CJ7
Thanks Scott. I have the kit already so, I just have to do it. No excuses.
"At first you don't succeed, get a bigger Hammer!"
in memory of Jimmy Smith - a wise man
Gido is offline   Reply With Quote Quick reply to this message
Unread 04-15-2012, 07:22 PM   #48
pman
pman's Avatar
Let us know how much trash you find in the bowl when you pull it apart
Gido, are you right close to Ocean Pond? Spent a good bit of time down there on that water growing up!
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
http://www.jeepforum.com/forum/f8/cj...-lulu-1350563/
pman is offline   Reply With Quote Quick reply to this message
Unread 04-15-2012, 07:27 PM   #49
Skerr
No... he's a couple hours away. I'm about 30 minutes.
Kerrdog
Go Fish! <*////><
Unread 04-15-2012, 07:40 PM   #50
Gido
1980 CJ7
Worked alot around that area. Scott, if your only 30 min from there might want to put a leash on clays jeep. Lolololololol.
Unread 04-15-2012, 07:48 PM   #51
pman
pman's Avatar
Ah! The reference to Olustee threw me off, Skerr!!
Unread 04-15-2012, 07:52 PM   #52
Gido
1980 CJ7
Spent the time flying around looking for night hunters.
Unread 04-17-2012, 04:13 PM   #53
Gido
1980 CJ7
All I can say is holy CRAP!!! I hope my homemade shaker works. I couldn't get the jets out. Didn't try very hard. I will have to get a power valve. It is shot. I don't know how this thing was running.
image-280823509.jpg   image-4267599545.jpg   image-3845633116.jpg   image-2585009544.jpg   image-479589356.jpg
Unread 04-17-2012, 04:20 PM   #54
Skerr
That last pic!!! That is soooo Redneck!! Rebuild kit should have a power valve in it, although mine didn't fit.
Kerrdog
Go Fish! <*////><
Unread 04-17-2012, 04:55 PM   #55
Gido
1980 CJ7
I am starting to wonder if I got the wrong kit. My jeep is an 80 model but it's. OT the original engine and the fuel pump that I replaced was from a 74 model 304. Would there be a difference in the model carburetor?
Unread 04-17-2012, 05:12 PM   #56
Skerr
Gido, I had the same PW. I think it is for the 2150. I reused mine. My gaskets were correct however. I don't know what you have with that gasket. Does it fit, and you need to make your own holes??
Kerrdog
Go Fish! <*////><
Unread 04-17-2012, 05:40 PM   #57
Gido
1980 CJ7
No it doesn't fit. Too small to make holes. My power valve is bad. The gasket inside is cracking bad.
Unread 04-17-2012, 06:44 PM   #58
pman
pman's Avatar
That's def a 2150 kit. My Wagoneer takes that one. If I was at home I could tell you the right kit #(I'm in Tamper, Fl..hangin' with your Florida Cracker boys).
Edit: just did some quality hotel research. The PV in your kit is a two stage PV, vs a single stage. Still researching... I'm stumped. Still don't understand why that's the only gasket you received either.
Unread 04-17-2012, 07:02 PM   #59
Gido
1980 CJ7
What the heck r u doin hanging with Florida crackas? I was born in Tampa and lived there till I was about 13.
Unread 04-17-2012, 07:09 PM   #60
pman
pman's Avatar
Trying to drum up some bidness with the Outback Restaurant people!! Good town you grew up in!
Gido, I just found this...Where's JeepHammer when ya need 'em?
http://www.jeepforum.com/forum/f8/si...valve-1240330/
