Bad Ignition Coil? - JeepForum.com
post #1 of 10 Old 08-18-2013, 12:29 PM Thread Starter
adhdeej
1979 CJ5
Bad Ignition Coil?
After a year of browsing the this splendid forum, under the radar, I decided it's time I finally register. So nice to meet all of you, and I can't wait to learn from some on the best.
Todays issue is... Ignition coil
I decided to test it by pulling the plug and grounding it to the engine block. The spark coming from the cable was orange, I first saw it when the spark transferred to my hand ( great shock to wake me up ). Is this a sure sign of a failing ignition coil, or am I just an amateur with more money to spend than brains to diagnose?
adhdeej is offline
post #2 of 10 Old 08-18-2013, 12:49 PM
LumpyGrits
No and maybe.........
Why do you think you have a coil issue to begin with?
LG
LumpyGrits is offline
post #3 of 10 Old 08-18-2013, 12:51 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Coils are tested with a Volts/Ohms Multi-Meter.
CJ7-Tim is offline
post #4 of 10 Old 08-18-2013, 12:53 PM
roboto65
1976 CJ5
Not Fingers
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline
post #5 of 10 Old 08-18-2013, 01:11 PM
CJ7-Tim
CJ7-Tim's Avatar
I can test a 9 volt battery by licking it, why not test a coil by holding on ?
CJ7-Tim is offline
post #6 of 10 Old 08-18-2013, 01:36 PM
LumpyGrits
Most folk only do that once......
LG
Have'n you along, is like loose'n 2 good men
post #7 of 10 Old 08-18-2013, 09:28 PM
86cj74.2L
86cj74.2L's Avatar
If you stick a screwdriver in the plug boot and hold the shaft close to a ground is the color still orange with a fully charged battery?
If its orange at 1/4 inch it fails my test. Especially if the primary and secondary resistance readings are close to out of spec.
86cj74.2L is offline
post #8 of 10 Old 08-19-2013, 03:54 PM Thread Starter
adhdeej
1979 CJ5
I went ahead and replaced it anyways, 20 dollars to get the nasty one outta there. Now I have to find out how to get the timing fixed and the dreaded headers to stop leaking.
adhdeej is offline
post #9 of 10 Old 08-19-2013, 04:04 PM
LumpyGrits
1 Get an FSM and a timing light.
2 Get a wrench/socket on those bolts.
$20.00 for a coil. Where was it made?
LG
post #10 of 10 Old 08-21-2013, 03:12 AM
BagusJeep
1981 CJ7
The coil is a simple transformer with two coil windings. All you need is a resistance meter to check the resistance of each.
As to the ignition, a timing light is indeed required but once mastered is straight forward enough. You can also use it to check the vacuum advance and timing curve if you want to get fancy.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
