BAD CJ mileage!!!! - JeepForum.com
post #1 of 17 Old 05-19-2013, 09:52 AM Thread Starter
cowboy24
BAD CJ mileage!!!!
OK, never posted before, but I really need some suggestions-- I built an 85 cj7 with a 383 stroker, 600 cfm holley, B=M turbo 350, NP206, AMC 20 rear w/ forged axles, but left the stock 2.73 gears, thinking of highway (75mph)mileage and RPM. I'm turning 2200 at 75 (33x12.50 procomps) and the BEST mileage I got was 10.2 WTF!!!! what did I do to get such lousy mileage? this same motor in a 70 elgambino got 18 on the highway (and turned 12's in 1/4 mile) any thoughts or suggestions would be GREATLY appreciated. thanks guys!!!
85 CJ7 ZZ383 stroker(for sale or trade) '10 RUBI unlimited, '04 WJ overland
cowboy24 is offline
post #2 of 17 Old 05-19-2013, 09:57 AM
wlo2000
Well you are driving a Brick aerodynamics-wise..Plus 33's aren't helping. I get about 9 with my LJ with the straight six with 3.73 gears and 35's and mine is a six speed manual..Over 55, the gas mileage dramatically decreases.
wlo2000 is offline
post #3 of 17 Old 05-19-2013, 10:07 AM
Jack61
1981 CJ7
I'm thinking that the engine is working pretty hard to push the Jeep with that gearing, auto trans and lack of aerodynamics. It is possible that the amount of load on the engine that the secondaries (if vacuum) are opening. Other factors like what rpm range the cam is designed to work in, if the carb is properly tuned (especially the power valve) and if the timing is properly set including total advance can have negative effects on power and mileage.
It used to be, God bless America, it has become God help America
Jack61 is offline
post #4 of 17 Old 05-19-2013, 10:49 AM
John Strenk
John Strenk's Avatar
1976 CJ5
What he said
plus, what tires? What weight?
All that leads to rolling resistance which sucks the gas right out of your wallet.
John Strenk is offline
post #5 of 17 Old 05-19-2013, 11:17 AM
Nereussailor
Originally Posted by wlo2000 View Post
well you are driving a brick
x2
I'm not sure what tomorrow will bring, but it can't be any worse than what I've already been through.
Nereussailor is offline
post #6 of 17 Old 05-19-2013, 12:24 PM
titomars
1981 CJ7
I have a CJ7, The engine is a modified and built 258 with a ported 4.0 HO head and a Holley T/A 470 CFM. It has a T-5 with 4:10's on 33X12.50 GY MTR's. The thing gets around 11 MPG in town and offroad. It gets at best close to 13.5 MPG on the freeway doing a calm 65 MPH.
They are bricks on wheels you can't expect Prius economy from them.
Your axle gears are your problem. That 70 ElCamino did not come with 2:75 gears. It most likely had 3:23's or 3:73 plus your tire diameter was most likely in the 26 to 27 inch range so really there is no comparison. Lugging the engine around will kill mileage. So stepping on the accelerator in very low RPM and you go right into the power valve circuit.
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #7 of 17 Old 05-19-2013, 02:34 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Maybe get a Honda.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #8 of 17 Old 05-19-2013, 03:32 PM
74Maverick
Tires hurt, aerodynamics hurt. Compound those at 75 and your screwed. I guarantee if you limit yourself(I wouldnt) to 65. You'll see a 2- mpg difference. And even though you have plenty of hp those gears on 33s will suck down extra fuel at lower speeds. Check a tire/gearing chart for fuel economy gears and you'll see.
The Last Great American Hero... the demi-god... to which speed means freedom of the soul.
74Maverick is offline
post #9 of 17 Old 05-19-2013, 05:24 PM
swatson454
1983 CJ7
You live in Elkotraz? Holy moly I spent too much time underground up there.
Anyways, I'll second everything the guys have said. At that speed, I'd personally like to see another 500 rpm. She's a luggin' and the PV is probably open.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #10 of 17 Old 05-19-2013, 06:20 PM
brownbagg
1930 MK Compass
hook a vacuums gauge so you can see it while driving
brownbagg is offline
post #11 of 17 Old 05-19-2013, 07:57 PM
Turokman123
Originally Posted by Nereussailor View Post
x2
x3. I'm driving with a 302 and 35's getting about 8 in town. It's in the rules, don't get a Jeep if you want good mileage
1984 CJ7 riding on 35" Wrangler DuraWalls, 4 inch lift, Dana 30 axle in front, with an AMC 20 rear axle. The Dana 300 two-speed transfer case; gear ratio of 3.54:1. Qualifications for a wave: 1: Top off 2: Any mud on the Jeep 3: Non-stock tires (not lowered) .
Turokman123 is offline
post #12 of 17 Old 05-19-2013, 09:59 PM
Jack61
1981 CJ7
That's not true. If cruising conservatively I can get close to 18 mpg, have even gotten close to 20 with the 351w I just replaced.
Jack61 is offline
post #13 of 17 Old 05-19-2013, 10:02 PM
74Maverick
Not saying i dont believe you, it is possible from a 55mph tank long cruise but have you corrected your speedometer/odometer gear.
post #14 of 17 Old 05-20-2013, 04:54 AM
John Strenk
1976 CJ5
I get 18 to 20 MPG with mine also on 33's with 3.54 gears with corrected speedometer.
But i'm running AT tires not MT tires.
post #15 of 17 Old 05-20-2013, 06:39 AM
Jack61
1981 CJ7
Yes speedometer is dead on. Cruising speed is 65-70 mph. 35s with 4.56 gears and 5 speed work very well together, the old engine had a decent 325 hp where the new engine is about 430 hp so it doesn't need to work hard at cruising speeds. Vacuum is high, well out of the power valve circuit, has the second to the heaviest spring in the secondary's and timing is nearly fully advanced. Not that I'm trying to get best mileage because it is to fun to drive but I do expect mileage from the new engine to go up some as it gets broke in more.
Jack61 is offline
