Backfiring - JeepForum.com
post #1 of 8 Old 09-02-2002, 08:41 PM Thread Starter
NMullens
NMullens's Avatar
Backfiring
My 258 doesnt seem to breathe too well. If the RPMs get high, a few moments later (as soon as I let off the gas) there is a huge backfire. It sounds like a shotgun. Any time I let off the gas and am not stopped there is a rumble in the exhaust. Does anyone have any ideas? Thanks. Nathan
Currently Jeepless - Previously owned 1983 SJ, 1979 CJ-7 and 1991 YJ
NMullens is offline
post #2 of 8 Old 09-02-2002, 09:20 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Re: Backfiring
Your Jeep is definately sucking air in from somewhere - most likely the exhaust manifold to head connection.
Steve
OldJeepguy is offline
post #3 of 8 Old 09-03-2002, 08:49 PM Thread Starter
NMullens
NMullens's Avatar
Thanks. Is this something that could be solved by tightening loose manifold bolts?
NMullens is offline
post #4 of 8 Old 09-03-2002, 09:48 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Sometimes but usually need to replace the gasket.
Steve
post #5 of 8 Old 09-04-2002, 07:15 PM Thread Starter
NMullens
NMullens's Avatar
That's strange because I just replaced the gaskets about a month ago and the Jeep hasn't been run much to break them in. Could they have been installed wrong? It's not that complicated is it or is there a break in time for new gaskets?
Thanks again JeepGuy.
NMullens is offline
post #6 of 8 Old 09-04-2002, 11:33 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Check ALL the connections! Especially The joint between the pipe and the manifold. You may of damaged the doughnut while replacing the manifold gasket.
jeepdaddy2000 is offline
post #7 of 8 Old 09-05-2002, 04:05 PM
MR.CJ-7
Mine was doing that too! I thought it was through the exhaust being that I have headers and very short cherry bombs out the fenderwell, but I had the carb rebuilt for a bad powervalve. With that and a choke adjustment the backfiring when letting off the throttle was gone.
Just my $.02 worth though.
Former CJ'er
MR.CJ-7 is offline
post #8 of 8 Old 09-05-2002, 07:43 PM Thread Starter
NMullens
NMullens's Avatar
Im not even sure what a powervalve is in the carb, I'll have to look that one up. Thanks for all the feedback though.
NMullens is offline
Backfiring? 5STRINGINIT Jeep CJ Forum 7 08-21-2007 09:21 PM
Backfiring woody-77 Jeep CJ Forum 5 08-20-2007 01:33 PM
Backfiring help jrylb73 Jeep CJ Forum 0 04-23-2007 05:03 PM
backfiring? thebeast77 Jeep CJ Forum 3 06-11-2006 05:46 PM
backfiring... chubsmalone Jeep CJ Forum 6 04-19-2004 02:00 PM
