Backfire and weber tune help - JeepForum.com
post #1 of 5 Old 03-01-2007, 10:27 PM Thread Starter
rb85cj7-82cj8
Okay here is the situation. I have a weber on my 258 with no ECM (82 didn't have it). All the emissions stuff is still intact. Original ignition. Mr. Gasket fuel pressure reg.
I am getting a backfire on deceleration from high speeds 45+. The kicker is that if i keep the accelerator depressed slightly it doesn't do it.
Have checked the timing and taken it as high as 12 and as low as 6. Have re-tuned the carb.
Went to O'reily's today and rented their compression tool and going to check that tomorrow night. also picked up a vacuum gauge and going to check for leaks there.
I don't know what else to include. Any thoughts or suggestions?
rb85cj7-82cj8 is offline
post #2 of 5 Old 03-02-2007, 05:18 AM
CJ5_Renegade
Try here: http://webernorthamerica.com/pdffile...otingguide.pdf
Not sure, but it sounds like a fuel pressure problem to me.
CJ5_Renegade is offline
post #3 of 5 Old 03-02-2007, 07:22 PM Thread Starter
rb85cj7-82cj8
I just did a vacuum test on it and it has a huge spike (6 deg) higher when you let of the gas. It runs at 19 and spikes to 25 when i let off.
post #4 of 5 Old 03-02-2007, 08:23 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
I'm with the feul pressure..I have never been found of those dial-a-matic regulators..Its best if you have one is to put an inline feul gauge to verify the pressure..Also do you have a return line to the tank...The vacume is normal in my circumstances to spike high when reveed and the throttle plates are sharply close,it creates alot of vacuum in the manifold by the higher rpm's wanting to drawl in X amount of air and the throttle plates are closed creating a blockage of sorts..I would check into the feul pressure and timing..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #5 of 5 Old 03-02-2007, 08:58 PM Thread Starter
rb85cj7-82cj8
Okay so i have kinda fixed it. I pulled the belt off the smog pump and no more pop. I will still check the fuel pressure tonight or in the morning.
thanks for the input.
Next question is can I drive my Jeep with the just the belt off the pump and all the hoses still hooked up?
WEBER 34 DGEC Carb TOO RICH??, Jets & Tune for Jeep 4.2 / 258 Fjguercio Jeep CJ Forum 55 05-13-2009 01:14 PM
AMC 360 backfire CJ Runner Jeep CJ Forum 10 03-01-2009 06:11 PM
258 Backfire 479AZ Jeep CJ Forum 25 01-10-2009 12:28 AM
Who is the Weber Tune Guru? b.d.d. Jeep CJ Forum 4 07-26-2008 04:41 PM
backfire marycatherine Jeep CJ Forum 8 01-20-2008 09:23 AM
