Back Splash out the vent hose - JeepForum.com
post #1 of 9 Old 01-02-2010, 07:54 AM Thread Starter
MontiyCJ7
1980 CJ7
I'd like to ask the master minds of this forum for some ideas of how to stop gas from rocketing out of the filler vent hose on my 1980 CJ7. I 've searched the threads and found nothing that would help me. Problem: when filling up and near "top off" gas willl shoot up through the vent hose (not the main filler hose) and shoot out all over. I have the vent hose out and thought of putting some kind of check valve (that i can't find) or something else to stop or slow down this gas problem. I know I can put my ear to the tank on fill ups and listen but, since I have the hose out I thought I could do something about this. I need some help please. Thanks for your time!
MontiyCJ7 is offline
post #2 of 9 Old 01-02-2010, 08:21 AM
halpeters
1978 CJ7
It is a rubber hose that runs from the tank to the filler neck.
Some ideas...
Try putting a hose clamp about half way down the rubber hose to choke off part of the flow.
Make sure the hose isn't being pinched at the bend next to the filler...
Hal
1978 CJ-7
halpeters is offline
post #3 of 9 Old 01-02-2010, 05:29 PM Thread Starter
MontiyCJ7
1980 CJ7
Thanks Hal. I thought of putting something inside the hose to help stop the sudden burst of gas coming up through the vent hose. Any ideas that would be gas resistant? I don't understand why the vent hose has such a large diameter. Still looking for more other ideas.
post #4 of 9 Old 01-02-2010, 07:01 PM
oofrog
1981 CJ7
i had an issue when it was full, and i was on a fairly extreme angle, that gas was pouring out of it, lost about 1/4 of a tank as we towed me out???
is there anything that can be done to stop this?
oofrog is offline
post #5 of 9 Old 01-02-2010, 07:36 PM
keith460
Jeep. There's Only One
keith460's Avatar
Are you sure you have the correct filler and vent hoses connected correctly? The vent hose should be off the top of the tank and has a formed bend or hump molded in place to prevent gas from shooting out. Plus, the metal filler neck has two vent exit ports built into it that splits the air escaping from the tank. If you are over filling the gas tank, fuel would exit from the fill tube instead first because it is mounted lower on the tank than the vent tube.
Replace your gas cap gasket or just buy a new gas cap. Fuel should not spill out as the cap prevents this and keeps fuel confined to the filler neck area and the fuel will drain back into the tank. No automobile designed is allowed to have fuel leak from the cap as per Safety and EPA regulations.
1984 CJ-7 Renegade
keith460 is offline
post #6 of 9 Old 01-02-2010, 10:54 PM
PERK
is your tank vented to the charcoal cannister?
PERK is offline
post #7 of 9 Old 01-03-2010, 10:05 AM
Mike Romain
Well, gas is supposed to come out this 'vent' hose when the tank is full to shut off the automatic gas filler nozzles. I believe that is the main purpose for this line.
That is actually one of the 'fixes' to turn some YJ 15 gallon gas tanks into a 20 gallon gas tanks. They have the hose set deep enough that gas pours out the vent tube at the 15 gallon mark, folks move it up and can put in 20 gallons.
That said, maybe you just need to slow down the rate of fill when it gets near full or find a gas station that has those splash guards (made just for this problem) on their pump nozzles. Gas blows back out of most gas tank fillers if you don't slow the pump down near the end. My CJ's sure will...
Mike
Mike Romain is offline
post #8 of 9 Old 01-03-2010, 09:05 PM Thread Starter
MontiyCJ7
1980 CJ7
Thanks guys for all the great comments. I thought that there would be a quick fix but, I guess I'll look for a gas station with that splash guard on the pump handle. If I have a charcoal cannister could I use the idea and reduce the diameter of the vent hose?
post #9 of 9 Old 01-04-2010, 06:49 AM
Mike Romain
The hose in question is not a 'vent' hose. It is a shut off hose for an automatic gas filler nozzle. When you close the gas cap, this line is as closed as the fill line.
The gas tank still needs a vent hose or it can get a vacuum on it causing the engine to run out of gas if sealed and if left open bad raw gas fumes escape.
Mike
1977 CJ7 Fuel Filler Hose and Vent Hose elybarnard Jeep CJ Forum 8 07-26-2009 09:29 AM
gas tank no vent hose? shok47 Jeep CJ Forum 6 07-05-2009 10:09 PM
amc model 20 vent hose jallen760 Jeep CJ Forum 5 10-19-2008 06:46 PM
What size vent hose? JOKER4INK Jeep CJ Forum 2 07-29-2006 12:58 AM
Vent hose in AMC 20 missing cjheven Jeep CJ Forum 2 04-13-2006 10:09 AM
