Axls and Leaf springs coated with Boiled linseed oil - JeepForum.com
post #1 of 6 Old 01-27-2010, 11:32 AM Thread Starter
semaJ
1979 CJ7
So here is my plan to wirewheel the axls and leaf springs then slather a bunch of boiled linseed oil all over them (mainly because i am super cheap and it is only going to cost me like $15) . I have not heard of of a many people doing this most use POR 15 or some other paint/rust preventitive.
So my questions are will boiled linseed oil work?
and
Is it that much better to use por 15 or a similar product?
Thanks in advance
semaJ
"Any fool can make a rule, and any fool can mind it" - Thoreau
semaJ is offline
post #2 of 6 Old 01-27-2010, 12:10 PM
frank c
1981 CJ5
Are you SERIOUS ???
Linseed oil will have every speck of dust dirt and whathave you clinging to it.
Your axels arent wooden are they ??
If they were it would soak in but metal ????
If you're goin thru the trouble to wire brush them down why not shoot a couple cans of derusto from wallyworld about 10 jeep bucks
frank c is offline
post #3 of 6 Old 01-27-2010, 12:19 PM
BioTex
1979 CJ7
I think he's refering to guys who coat the inside of their frames with linseed oil as a rust preventative. This is obviously because you can't get to the inside of the frame to paint with anything. Linseed oil is better than nothing in this case.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #4 of 6 Old 01-27-2010, 12:43 PM
kickingprop
Yeah I think a couple cans of Rust-o-leum is a better alternative and should be just fine... Linseed Oil is a stopgap measure for inside frames as BioTex said.
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline
post #5 of 6 Old 01-27-2010, 01:12 PM Thread Starter
semaJ
1979 CJ7
Sweet guys that is exactly why I asked. I knew there was a reason.
semaJ is offline
post #6 of 6 Old 01-27-2010, 01:17 PM
cowdodger1
That probably won't work. Your axles and springs are going to be exposed to a lot of harsh conditions exposed as the are to the elements. Linseed oil will probably be fine as a coating inside a frame where it's more protected. I'm an engineer on ships. There is an old school use of linseed oil as a preservative on uninsulated low pressure steam pipes out on the weather decks. The pipe would be heated with an oxi-acetylene torch and then coated with linseed oil. It worked, but not for too long. It would have to be re-coated once or twice a year. This was used a lot on fishing boats.
cowdodger1 is offline
Leaf Springs Help rrtex1 Jeep CJ Forum 21 12-10-2009 02:16 PM
cj5 leaf springs vs. cj7 leaf springs tcwinters5 Jeep CJ Forum 2 12-07-2009 07:06 PM
Leaf Springs rrtex1 Jeep CJ Forum 2 12-07-2009 01:35 PM
Old Man Emu leaf springs Brazos Jeep CJ Forum 7 02-17-2006 01:44 PM
Chevy Axls Cj5 heywoodyablowme Jeep CJ Forum 2 05-03-2005 11:08 PM
