axles for a CJ5 - JeepForum.com
post #1 of 6 Old 05-15-2003, 01:58 PM Thread Starter
soler
axles for a CJ5
Will 1985 cherokee axles work on my 58 willys? Are they strong enough for some power?
soler is offline
post #2 of 6 Old 05-15-2003, 02:53 PM
CSP
The front diff is on the wrong side for your Willy's. The rear one is also centered and you need an offset axle in the rear. Dana 44's from any '74-79 Wagoneer would work much better.
Whether they work with "power" depends on how much power you're talking about. It also depends on gearing and tire size.
Do a little searching on CJ axle swaps on one of the search engine websites and you'll find all sorts of info.
CSP is offline
post #3 of 6 Old 05-15-2003, 05:20 PM
TheJeepGod
i agree with the 74-79 axles. but the wagoneers were often geared high (3.73 or higher) you might be able to find some with at least 4.88, but if you want the 5.38's that your '58 had youll probably have to swap gears.
1951 CJ-3A-Chevy V-8, 2.5" Lift Still Going Strong, but In need of restoration (eventually)
1970 CJ-5- Fully restored-saginaw ps, lift, 33's, rear locker etc.
1999 Cherokee
2001 Cherokee 60th Anniversary
2007 WK CRD
TheJeepGod is offline
post #4 of 6 Old 05-15-2003, 09:46 PM
rustyCJ
your transfer case front output in on the passenger side, the rear output is also on the passenger side directly behind the front output. you are going to need a front axle with the pumpkin on the passenger side and a rear with the diff offset to the passenger side.
there are really only 4 ways you could go bout getting new axles
1. pull some from something like a waggy
2. get some fullsize truck axles and cut um down to size offseting the rear to the passenger side
3. buy my offset narrowtrack AMC20 rear and my narrowtrack dana30 front
4. buy some brand new custom made axles
i personnally feel the 3rd option is best.......lol
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #5 of 6 Old 05-16-2003, 09:20 AM Thread Starter
soler
ok im biting
How much? Pm me
soler is offline
post #6 of 6 Old 05-16-2003, 02:49 PM
rustyCJ
i not going to ship these so you would have to pick um up. i am in central IL, still interested?
rustyCJ is offline
J10 axles on my CJ xulcuz Jeep CJ Forum 8 03-04-2012 01:16 PM
id these axles please hethcox Jeep CJ Forum 8 10-11-2008 08:45 PM
cj7 axles in a cj5? tawdr77 Jeep CJ Forum 5 09-29-2008 06:02 AM
axles jeepboy90 Jeep CJ Forum 23 03-31-2006 08:17 AM
Axles? Fropleyqk Jeep CJ Forum 17 03-20-2005 10:34 AM
