Axle U-Joints for Dana 30 - JeepForum.com
post #1 of 17 Old 08-24-2009, 09:46 PM Thread Starter
shok47
1983 CJ7
I need to by a u joint for the driver side on my 83 cj7. I know there are alot of different kinds, and depending on the year of the axle, it will have different size rotors and stuff like that. I need to verify that this would be the right size for me. Dana Spicer 5-260X U Joint Dana 30 Axle U Joint:eBay Motors (item 140335377417 end time Sep-22-09 09:05:54 PDT)
shok47 is offline
post #2 of 17 Old 08-25-2009, 12:20 AM
OldSailor
1977 CJ7
Any decent auto parts store should be able to get you the correct u-joints for your front halfshafts. I personally get the ones that are pre-greased and do NOT have a zerk fitting on them. I feel that the lack of a holt in the cross makes it just a little stronger.
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc.
OldSailor is offline
post #3 of 17 Old 08-25-2009, 01:58 AM
ksheffer08
1981 CJ7
non greasable u joints are stronger, and i beleive the 5-760x will work, it is the stronger replacement for the 5-297x. you should be able to get a set locally.
i prefer spicer.
ksheffer08 is offline
post #4 of 17 Old 08-25-2009, 02:44 AM
JeepinYahoo
JeepinYahoo's Avatar
1977 CJ5
You can just get the kind that grease through the caps...then there is no hole in the cross to weaken them.
'77 CJ-5---'63 Scout 80 FOR SALE---'71 Scout 800B---'78 F-250 Camper Special---'75 Econoline 100
JeepinYahoo is offline
post #5 of 17 Old 08-25-2009, 05:30 AM
foggybottombob
I think the CJ7 dana 30 uses the smaller u-joint. And I think 5-260X is the number for it. The 5-297x and 5-760x are larger and will not fit. This is the way I remember it from when I swapped out my dana 30 a few years ago. I swapped in a scout axle and the scout axle had a stub shaft that was the same spline as the dana 30 stub but it used a bigger u-joint. I don't remember that any CJ7 dana 30 ever used the larger u-joint.
foggybottombob is offline
post #6 of 17 Old 08-25-2009, 06:30 AM
DT5150
1983 CJ7
^ i think he's right. it's the 260 size u-joint. and get spicers.
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline
post #7 of 17 Old 08-25-2009, 07:11 AM Thread Starter
shok47
1983 CJ7
Thanks for the help! Where do you guys get them locally? I went to Autozone and they only had Duralast, I bought it but returned it.
shok47 is offline
post #8 of 17 Old 08-25-2009, 07:40 AM
DT5150
1983 CJ7
i wanted spicers too, had to order em online. couldn't find any locally.
DT5150 is offline
post #9 of 17 Old 08-25-2009, 08:08 AM
JrTjK
1978 FSJ Wagoneer
Jeep CJ Front Axle (1976-1986) | Crown Automotive Sales
8126616 or 8126637SP would be the right part for you...sent you a pm. Depending on where you are in MA, I could tell you plenty of local places that would have the right parts for you in stock.
JrTjK is offline
post #10 of 17 Old 08-26-2009, 03:52 PM Thread Starter
shok47
1983 CJ7
hey thanks ALOT! I can really use your help. I live in western mass, I dont know if you got my PM but my mail was full; only allows like 4 msg's...
shok47 is offline
post #11 of 17 Old 08-26-2009, 06:58 PM
rixcj
rixcj's Avatar
1979 CJ5
Driveshaft shops often carry Spicer u-joints.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #12 of 17 Old 08-26-2009, 07:31 PM
VACJ7
VACJ7's Avatar
Rich
Yep, that's where I picked up my Spicer 5-260X's for my D30 last week.
VACJ7 is offline
post #13 of 17 Old 09-14-2009, 09:36 AM
Midwestdrivesha
Spicer 5-260x if you're still looking for them online
Midwestdrivesha is offline
post #14 of 17 Old 09-14-2009, 09:48 AM
datmony
Napa generally carries them or also like was mentioned, any good driveline ship will have them too.
datmony is offline
post #15 of 17 Old 09-14-2009, 10:05 AM
Blthomas
Blthomas's Avatar
1979 CJ7
I am running the Duralasts in my driveshafts and front axleshafts and no worries as of yet. I'm not super hard on it, but I get in some situations none the less.
I'm a fan of spicers also, they are in my bigger Ford's. Just couldn't find them when I busted a axle shaft u-joint couple weeks ago.
I'm going to run the duralasts and see how they do.
79' CJ7 - 4" lift, 33's
81' CJ8 bone stock
80' Chief "S" 6" lift, 33's
Blthomas is offline
how far do new ball joints go in? dana 44 mowjoecj Jeep CJ Forum 3 01-21-2010 01:48 PM
Dana 44 / Spicer 20 U-Joints? ASteve Jeep CJ Forum 6 12-14-2009 05:13 PM
Dana 30 Axle U joints Killin me! I need some assistance. CJman77 Jeep CJ Forum 22 11-18-2009 07:50 AM
Dana 30 ball joints kcarlsonjeep Jeep CJ Forum 3 05-26-2009 01:14 PM
Dana 30 ball joints CJ Runner Jeep CJ Forum 5 04-03-2008 07:43 PM
