Axle U-Joint Question - JeepForum.com
post #1 of 8 Old 05-20-2003, 09:15 PM Thread Starter
TG CJ7
Im trying to replace the axle U-Joints in an '84 CJ. Im having trouble removing the locknuts on the axle so that I can remove the hub. I tried channel lock pliers and I dont have a large enough socket. Im sure lots of you guys have replaced the U-Joints before. What is the trick to those locknuts?
There are supposed to be two, Im on number one.
Thanks
Tim
1979 CJ7 Renegade 304, 3spd, 2.5 BDS lift, Hedman headers.
Check it out
TG CJ7 is offline
post #2 of 8 Old 05-20-2003, 09:24 PM
magicmudder
magicmudder's Avatar
Yeah, there are two of them. I went out and bought a socket from sears for $20 to take them off, but they didn't have hardly any torque on them at all. Make sure you've bent the tab back first (on the washer behind the nuts that keeps them in place) and you should be able to gently hit one corner with a punch to get the nut to turn or you could go buy a socket
84 CJ7, 258, shackle reversal, 4.56 gears, lockrite , moser one piece axles, 37" SSR's
magicmudder is offline
post #3 of 8 Old 05-20-2003, 09:26 PM
rustyCJ
three words: spindle nut socket, 4wd hardware has them for $9.99 and anything under $10 is free shipping and they ship priority. i couldnt find the right size at any local autoparts stores. you could always use the redneck approach, a screwdriver and hammer.
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #4 of 8 Old 05-21-2003, 09:10 AM
CSP
Like rusty said, get the right socket. You'll have a helluva time getting the bearing preload correct when re-installing them without one. The correct size is 2-3/32". I bought mine from 4WD Hardware.
CSP is offline
post #5 of 8 Old 05-22-2003, 06:58 PM Thread Starter
TG CJ7
Okay that axle is out. Thanks a lot.
Now how do I go about replacing the axle u-joint? They'er not like a driveshaft U-joint; they seem to have caps on the end of them. Is that a cap or part of the u-joint?
I see they have C-clips on the bottom that look like they hold the u-joint in place. I did remove those.
Agian, thanks for your help.
Tim
Check it out
TG CJ7 is offline
post #6 of 8 Old 05-23-2003, 12:54 PM
rustyCJ
try reading this:
U-joints
rustyCJ is offline
post #7 of 8 Old 05-25-2003, 06:51 PM
CoryB
CoryB's Avatar
2015 JK Wrangler
Originally posted by rustyCJ
try reading this:
U-joints
In a perfect world, they might work like that. The joints on my 84 CJ7, however, were a different story. The writeup about my foray into axle-u-joint-land is here.
CoryB is offline
post #8 of 8 Old 05-26-2003, 01:16 PM
rustyCJ
actually in a perfect world someone who is about to change out their axle u-joints realizes they might be pretty rusty if they need changed so they start soaking them with penetrating oil everyday for a few days before they attempt it so they dont have to use a 60ton press and risk damaging the shafts. <-- thats a really long run-on sentence......lol
i havent ever tried doing it the way the link i posted does it. i built a press just for axle u-joints. doesnt take nothing to remove and install ujoints if you have the right tools. the link was posted because not everyone has access to a u-joint or 60ton press and it details how they go in and come out.
rustyCJ is offline
Dana 30 Axle U-Joint Question! CJman77 Jeep CJ Forum 4 04-01-2009 12:47 PM
dana 30 axle u joint need replacing...help! mike4089 Jeep CJ Forum 10 08-21-2008 11:25 PM
full width axle u joint question akashooter Jeep CJ Forum 1 11-14-2007 07:47 PM
Axle shaft U joint replacement HELP! xj89 Jeep CJ Forum 25 11-14-2007 06:53 AM
Front axle u-joint CjinPA Jeep CJ Forum 8 07-03-2006 12:11 AM
