Axle Swap Weekend (Picture Heavy) - JeepForum.com
post #1 of 20 Old 08-22-2010, 08:50 PM Thread Starter
MoC
Axle Swap & Truss Install Weekend (Picture Heavy)
Let me start by thanking everyone for answears to my questions over the last week or so. Also a HUGE thank you to LSUTiger for the help this weekend!! I bought a set of used widetrac axles off of Craigslist. Amc 20 with one piece shafts, rugged ridge diff cover, detroit locker, tubes welded. Dana 30 Loc Right locker, Chromoly draglink / tie rod with heims. Both have 4.88 gears. They were set up to run SOA. Also ordered a truss from Besrk, which I was more than pleased with. Both Saturday and Sunday were 100 plus degrees outside. Started by cutting the old perches of the axles so that I could set them back to SUA. Got the old front axle out, new one in and caster set to 8. Then tacked the front, pulled it out and finished welds on the perches. Got it painted and reinstalled. After the the rear came out. New rear went in, rear yoke set 2 degrees lower that the tcase yoke, the perches tacked.The only took about 9 hours with a few breaks here and there.
MoC is offline
post #2 of 20 Old 08-22-2010, 08:54 PM Thread Starter
MoC
Today took the rear back out. Got the perches welded, truss installed and the axle back under the jeep. Truss got welded with a combo of Mig and Tig.
MoC is offline
post #3 of 20 Old 08-22-2010, 08:58 PM Thread Starter
MoC
Called it quits around 3pm. Next weekend I am going to switch out breaks, install lines, parking brake and bleed everything. Then flip the tie rod and drag link, drive shafts, install shocks, and axle vent lines. One more day!! Again thanks everyone for the help and the truss Rocks!! Thanks Besrk!
MoC is offline
post #4 of 20 Old 08-22-2010, 09:25 PM
Trapshooter
Wow....you were busy this weekend. Who is the manufacturer of the front shackles you have? Are you running YJ leaf spings?
Keep posting the pics, would like to see her all done.
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #5 of 20 Old 08-22-2010, 09:29 PM
Skerr
MoC! You Rock! Nice work. Nice shop too! What kind of spring plates are those? Are they factory??
Kerrdog
Go Fish! <*////><
Skerr is offline
post #6 of 20 Old 08-22-2010, 09:31 PM Thread Starter
MoC
The springs and shackles are all part of the RE 4.5" lift kit. The front springs in the RE lift are 2.5" wide like YJ springs.
MoC is offline
post #7 of 20 Old 08-22-2010, 09:40 PM Thread Starter
MoC
The spring plates are warrior 2.5 inch perches. Since I am running a RE lift with 2.5 fronts and rears I went with the larger perches for the front. I would love to claim the shop but it is not mine. Belongs to a buddy. The hot driveway is mine though!! The only problem I ran in to with the new perches was on the front install. The factory perches are small up front and inset to fit around the pumpkin. With the larger perches I had to grind the inside of one side out to get it to sit flat. The picture is of the old perch before I cut it off. For the truss I also had to relocate the rear axle breather. Took the old on out, welded the hole closed. Drilled a new hole and welded in a compressor fitting. Will post a picture of it tomorrow. Besrk gave me a great tip on drilling the new hole. If you keep the tip of the drill bit loaded up with grease most of the metal filings stick in the grease and stay out of the axle.
MoC is offline
post #8 of 20 Old 08-22-2010, 09:42 PM
Trapshooter
Gotcha......I'd love to install a RE 4.5 on my '86 CJ7. One of these days......
My 401 build:
post #9 of 20 Old 08-22-2010, 09:51 PM
Shasta69
1978 CJ7
what man cave has a vanity mirror in it?
nice post btw!
Shasta69 is offline
post #10 of 20 Old 08-22-2010, 11:18 PM Thread Starter
MoC
Another good tip is to make sure the ground that you are setting the front caster angle and rear driveline angles on is level. I normally do all my work in the backyard, however the concrete area back there was not level so I had to do it in the driveway.
MoC is offline
post #11 of 20 Old 08-23-2010, 08:10 AM
LSUtiger
1980 CJ5
The plates are the ones that come with the Rubicon lift kit.
"what man cave has a vanity mirror in it?"
LOL. He is a contractor who repairs old stuff in his spare time.
1980 cj5 401, t-176, p/s., YJ p/b, tfi/hei hybrid, 3.73 30/44
LSUtiger is offline
post #12 of 20 Old 08-23-2010, 02:24 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Nice work!! Truss looks good. I like that diff cover too.. I've never seen one like that before. Thanks for posting pics too!!
BESRK is offline
post #13 of 20 Old 08-23-2010, 03:45 PM Thread Starter
MoC
The rear diff cover is a Rugged Ridge cover. Thanks again for the truss!
If anyone is looking for an AMC 20 truss Besrk makes a GREAT one. He was quick on shipping and great with any questions I had.
MoC is offline
post #14 of 20 Old 08-23-2010, 06:57 PM
Shasta69
1978 CJ7
happen to know what type of filler rod the welder used? preheat? postheat?
Shasta69 is offline
post #15 of 20 Old 08-23-2010, 07:41 PM Thread Starter
MoC
He Tig'ed the cast nocular to the truss with a silica bronze rod I think. Everything stayed a little warm, maybe in the 200's while welding the truss. No direct post heat. We took about 3 hours total and the weld job, letting the tubes cool so they did not warp.
MoC is offline
Almost finished 1980 CJ-7 (Picture heavy ) dariopop Jeep CJ Forum 44 03-26-2012 07:41 PM
Last Questions Before Big Axle Replacement Weekend MoC Jeep CJ Forum 9 08-19-2010 02:41 PM
MY CJ7 build picture heavy ajstewart Jeep CJ Forum 15 06-12-2010 09:04 AM
My New 5! (PICTURE HEAVY) Forumpete58 Jeep CJ Forum 28 02-28-2010 09:09 AM
Brought home my 5 (picture heavy) Forumpete58 Jeep CJ Forum 9 05-23-2009 06:08 PM
