Axle Swap from narrow track to wide track - Page 2 - JeepForum.com
post #16 of 20 Old 04-28-2013, 09:06 PM
CSP
The T18 doesn't have synchros in first gear. Only second through fourth.
You would have had to move the perches for any '76 and up axle since the frame width at the rear is different.
CSP is offline
post #17 of 20 Old 04-28-2013, 11:21 PM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
My '79 frame rotted out. 15 years after I put a 'glass tub on it. I lucked out and found an immaculate '86 roller w/a D44 rear. I do NOT like the WT look at all. Pa, or at least the inspection stations near me, have strict laws about wheels sticking out beyond the flares, so 11.50s are about the limit. My 12.50s throw crud from a wet spot on the road all over my CJ, which I keep immaculate....when running!
I beat the snot out of my stock 20 (airborne etc) w/o any failures behind a warmed 304. I read all the "bad" things about the 20 rear and how the 44 was such a great improvement. I should have welded the tubes, trussed it and put in 1 pc axles. Selling the D44 would have covered alot of the 20 upgrades. Luckily it had HD tie rods, but even though I had the axles COMPLETELY apart to re-gear and add a tru-trac....I forgot to swap over my 6 bolt Warn premium hubs. Now I have a killer axle set w/cruddy plastic 5 bolt stock hubs. D'OH!
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #18 of 20 Old 05-02-2013, 08:42 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
What about shock mounts? Do you have to change them or can you run the shorter shock mounts on the frame?
Rick
Cutlass327 is offline
post #19 of 20 Old 05-02-2013, 01:04 PM
jeepwhore
If you use the spring plates used with NT axles you can keep the same shocks and frame mounts. If you mount the lower end of the shock on the WT axle tube mount you either need to get shorter shocks or replace the frame mounts with the taller variety.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #20 of 20 Old 05-02-2013, 02:26 PM
sanctified
Originally Posted by bobged1 View Post
I just swaped the narrow tracs out of my 75 for wide tracs out of an 84 and did have to mount new spring mounts on the rear I have a T18 4 speed I had 4:27 in it and went to a 2:73 so I could drive it faster than 45 miles per hour plus the ring and pinion in the front was gone. Now I am shifting different does the T18 have syncronizers in it
Are you gonna get rid of those 4.27's? I'm looking to regear.
2013 JK (see info on left)
SOLD: 1983 CJ7
Utah Jeep Crew #178
sanctified is offline
Narrow track to wide track swap, mods? greene76 Jeep CJ Forum 8 12-23-2009 09:00 AM
Narrow Track Steering Link vs. Wide Track?? olcj Jeep CJ Forum 3 05-18-2009 10:38 PM
amc 20 narrow to wide track gear swap questions piecesnparts Jeep CJ Forum 9 01-12-2009 06:07 PM
Front axle wide track/narrow track?? Joey_B Jeep CJ Forum 17 10-16-2006 03:44 PM
ring and Pinion swap from Narrow Track to Wide Track From78To83 Jeep CJ Forum 1 04-05-2005 02:15 PM
