Axle Swap from narrow track to wide track - JeepForum.com
post #1 of 20 Old 07-24-2009, 10:55 AM Thread Starter
1979CJ7newguy
1979 CJ7
I have a 1979 CJ7 with the narrow track axles. Can I swap those out for the wide track axles from an 82-86 CJ? If so, what else must i do to finish the job?
1979CJ7newguy is offline
post #2 of 20 Old 07-24-2009, 11:02 AM
rustymudder
1982 CJ7
yup, should be plug and play. They are identical except for the width.
rustymudder is offline
post #3 of 20 Old 07-24-2009, 11:25 AM Thread Starter
1979CJ7newguy
1979 CJ7
Any reasons not to do the swap??
post #4 of 20 Old 07-24-2009, 11:50 AM
CSP
Steering linkage isn't identical. The wide track linkage must also come with the wider front axle.
Shock mounts are also different on wide tracks.
CSP is offline
post #5 of 20 Old 07-24-2009, 12:00 PM
Sundowners
Correct me if I'm wrong but couldn't you just change wheels from an 8" wide to a 10" wide with the same back spacing and gain almost the results as using a wide track with 8" wide wheels? This is assuming that you are currently using 8" wide wheels and something like 33x12.5 tires.
Sundowners is offline
post #6 of 20 Old 07-24-2009, 12:18 PM Thread Starter
1979CJ7newguy
1979 CJ7
Does the widetrack rear axle come with 2 piece axles just like the narrow track did?
post #7 of 20 Old 07-24-2009, 12:24 PM
Sundowners
Yes. you can get aftermarket 1 pc axles though.
post #8 of 20 Old 07-24-2009, 12:24 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Yes, they do.
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #9 of 20 Old 07-24-2009, 12:30 PM Thread Starter
1979CJ7newguy
1979 CJ7
Who or what brand makes a good 1 piece axle kit?
post #10 of 20 Old 07-24-2009, 12:35 PM
kickingprop
Moser, Yukon, Superior... Do some research on this topic...its one of the most widely covered
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline
post #11 of 20 Old 07-24-2009, 12:46 PM
JeepinYahoo
JeepinYahoo's Avatar
1977 CJ5
I think the NT hubs are also stronger, if I remember correctly the later CJ's had weak 6 bolt compared to the earlier 5 bolt design...or the other way around. I ran wheel spacers for years and it was good. I recently went back to stock width for nostalgic reasons.
'77 CJ-5---'63 Scout 80 FOR SALE---'71 Scout 800B---'78 F-250 Camper Special---'75 Econoline 100
JeepinYahoo is offline
post #12 of 20 Old 07-24-2009, 01:11 PM
kickingprop
yeah the old NT's had the 6bolt hubs and I know my WT has the 5bolt. But there is a thread for switching the WT's back to the 6bolt hub somewhere on here. I dont feel like searching for it though.
1985 CJ7 Project
post #13 of 20 Old 07-24-2009, 02:01 PM
CSP
No. You aren't spacing the wheels any further from the frame doing this. You'd have to go to a wheel with less backspace to do what going to wider axles does.
CSP is offline
post #14 of 20 Old 07-25-2009, 08:27 PM
T3hRustyWalnut
1979 CJ7
I just swapped out my NT axles to WT just over a month ago. Everything is a clean swap. I removed the hubs, rotors, brake horns and calipers from the NT which were 6 bolt and swapped out the hardware on the WT. The only other part you might need is the longer steering link for the WT axles, I actually have one from the donor vehicle still. Also, I don't know if it matters i changed the U joint straps (screw type) on the WT to the U-bolt style that the NT had.
For those who have and are serving our nation.
T3hRustyWalnut is offline
post #15 of 20 Old 04-28-2013, 04:33 PM
bobged1
1975 CJ6
I just swaped the narrow tracs out of my 75 for wide tracs out of an 84 and did have to mount new spring mounts on the rear I have a T18 4 speed I had 4:27 in it and went to a 2:73 so I could drive it faster than 45 miles per hour plus the ring and pinion in the front was gone. Now I am shifting different does the T18 have syncronizers in it
bobged1 is offline
Narrow track to wide track swap, mods? greene76 Jeep CJ Forum 8 12-23-2009 09:00 AM
Narrow Track Steering Link vs. Wide Track?? olcj Jeep CJ Forum 3 05-18-2009 10:38 PM
amc 20 narrow to wide track gear swap questions piecesnparts Jeep CJ Forum 9 01-12-2009 06:07 PM
Front axle wide track/narrow track?? Joey_B Jeep CJ Forum 17 10-16-2006 03:44 PM
ring and Pinion swap from Narrow Track to Wide Track From78To83 Jeep CJ Forum 1 04-05-2005 02:15 PM
