Axle Shaft Stuck - JeepForum.com
post #1 of 5 Old 09-23-2017, 06:58 PM Thread Starter
CJPondScum
Axle Shaft Stuck
Hello all! My driver side Axle shaft won't pull all the way out. It's getting stuck at the knuckles. Any suggestions?
CJPondScum is offline
post #2 of 5 Old 09-23-2017, 07:03 PM
skizriz
1978 CJ7
Ears are spread open a little bit. I've had it happen a few times. A piece of pipe, and a BFH, and a whack from the back side always got mine out.
skizriz is offline
post #3 of 5 Old 09-23-2017, 07:31 PM Thread Starter
CJPondScum
No luck yet... Will keep at it. Do you know if this is out far enough that i can pull the carrier? Or do the shafts need to be all the way out? My first time pulling a carrier.
Thanks Kev
post #4 of 5 Old 09-23-2017, 07:39 PM
Fourtrail
1974 CJ6
You should be able to see where it is rubbing. Have had to dress the corners of the ujoint caps to get it to slip in/out. You can also put a touch of a notch in the knuckle to get it out. I would think you are out far enough to clear the carrier.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is online now
post #5 of 5 Old 09-23-2017, 08:02 PM Thread Starter
CJPondScum
Success!! Thanks Gents!
