axle shaft seals - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > axle shaft seals
TeraFlex Now at Rockridge 4WD! BEST DEALS around!Alloy usa heavy duty ball joint kitsENGO QUADLUX 6" to 54" LED AMBER AND WHITE MULTI
Unread 10-23-2014, 04:12 PM   #1
dbla99
axle shaft seals
I am replacing spindle bearngs and seals on my 1979 jeep golden eagle.I am pretty sure it has a dana30 axle.In my factory service manual it shows replacing a seal behind the u-joint before it goes in the tube.I know there are seals in the tube before the differential but is there supposed to be seals here too. there are flanged collars here like on the other side of the u-joint for the spindle bearing seal but I can't find pics anywhere beside my manual. Any help would be greatly appreciated.
dbla99 is offline   Reply With Quote Quick reply to this message
Unread 10-23-2014, 09:18 PM   #2
LumpyGrits
That's not a true 'seal'.
It's just a dirt shield-Not a big deal.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline   Reply With Quote Quick reply to this message
