Axle Play - Bad Bearings? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Axle Play - Bad Bearings?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW ZJ Grand Cherokee Tube DoorsGibson WK HEMI 3" Catback - 5 Day Special!
Unread 08-27-2015, 02:19 PM   #1
cj7red
Took off my rear wheels to replace my spring bushings and immediately noticed some play in both axle shafts. Do I need to replace my wheel bearings?
Also, I found a hole in the top of the passenger side axle tube. Is that for a vent hose or did a previous owner mess it up?
I have an 85 cj7 with an AMC 20 rear. Stock axle shafts as far as I know. Any insight would be greatly appreciated.
cj7red is offline   Reply With Quote Quick reply to this message
Unread 08-27-2015, 02:21 PM   #2
cj7red
It is also apparent that the person who did the lift didn't install extended brake lines. That's next on my list.
Unread 08-27-2015, 04:48 PM   #3
OrangeCJ-5
OrangeCJ-5's Avatar
1978 CJ5
Passenger side viewed from the front looking back.
OrangeCJ-5 is offline   Reply With Quote Quick reply to this message
Unread 08-27-2015, 06:14 PM   #4
cj7red
Okay so it is a vent line. Are those easy to find on quadratec/4wd/morris4x4/etc?
Unread 08-27-2015, 06:59 PM   #5
80cj
80cj's Avatar
1980 CJ5
There are shims nder the drivers side backing plate to adjust axle bearing end play. That is assumng the bearings are OK.
80cj is online now   Reply With Quote Quick reply to this message
Unread 08-28-2015, 12:52 PM   #6
cj7red
Do the drivers side shims adjust bearing play for both ends?
Unread 08-28-2015, 03:44 PM   #7
80cj
80cj's Avatar
1980 CJ5
Yes, movement is transfered between both axles through the differential thrust block.
Unread Yesterday, 09:23 PM   #8
only in a jeep cj
If there is slight bearing wear, you can remove a shim or two and check specs. (IF you still have the oem two piece axle shafts)
Outside of that, its bearing time. Keep the shims for that time.
The vent hose isn't special, its the metal fitting that you need to find that presses into the tube hole .....tact weld it in place as it probably wont stay.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote Quick reply to this message
