Axle oil leak - JeepForum.com
post #1 of 5 Old 06-29-2003, 11:15 AM Thread Starter
gordonjs
Axle oil leak
I own an 81 CJ-7. Last year, it was leaking oil from the rear axle on the driver side. (The brake drum was covered in oil etc.) I had the oil seals and bearings replaced last summer, but now its leaking again. I recently parked on a slight uphill grade where the driver-side wheel was lower than the other, and nearly all the oil poured out onto the ground. Whats my problem now, if the seals and bearings are new?
gordonjs is offline
post #2 of 5 Old 06-30-2003, 09:31 AM
knowlwk@snowhill.com
1980 CJ7
Your axle tubes may be bent, that supposedly causes the new seals to leak soon after changing everything. I haven't had this happen to my rig, but thats what everyone told me when I fixed my leaking axle a year ago... so far, no leaks.
'80 CJ7, 258 W/Autojuicer, MC 2100, TFI, SummitRacing CDI, MORE SRS, Moser 1-pc, YJ tub on 1" body lift, YJ family cage.
knowlwk@snowhill.com is offline
post #3 of 5 Old 06-30-2003, 11:41 AM
CJMONEYPIT
make sure the vent tube on the axle is not clogged. If it is clogged, pressure builds up in the axle and blows the oil out through the seals.
- 83 Scrambler, AMC 360, Edelbrock intake, Howell fuel injection, 32in. BFG MT, 2in. Superlift, stock axles.
- 85 CJ-10a, work in progress
CJMONEYPIT is offline
post #4 of 5 Old 06-30-2003, 11:46 AM
explortainment
if the vent tube is clogged and forcing the gear fluid past the axle seals, will unclogging the vent tube fix the leaking? my axle leaks a bunch of fluid every once in a blue moon, but when it leaks... it leaks a lot, other times it doesn't leak at all.
explortainment is offline
post #5 of 5 Old 07-01-2003, 03:08 PM
dana60cj
dana60cj's Avatar
It could be an intermitant clog? Just make sure the axle vent is clear. When I checked mine I took it off and blew compressed air through it. Surprisingly alot of stuff came out, how it got there I don't know? It helped my repetitive leak. lol
'84 CJ-7, 6" lift, 33" BFG's, I6, .030 Over, Comp Cam, 400cfm Weber, K&N, T-18, 4 Core, Snorkel, D60 Detroit, Custom CV Driveshaft, 1350 U-Joints, D30 True Trac, Alloy shafts, S.R.S. w/ buggy springs, Custom Folding Shackles and Spring Hinges, Custum Tire Rack, Designed On Board Air, Optima's. Sneaky Jeep Owner #3.
dana60cj is offline
rear axle leak sstumble Jeep CJ Forum 1 08-12-2009 08:13 PM
71 cj5 axle leak jrm72 Jeep CJ Forum 3 04-09-2009 03:44 PM
Axle Leak Aggie99 Jeep CJ Forum 6 05-21-2008 02:42 PM
front axle leak certifiablejeep Jeep CJ Forum 2 06-02-2004 09:30 AM
AMC one piece axle leak. dana60cj Jeep CJ Forum 1 08-21-2002 07:57 PM
