Axle "Nubber" Question... - JeepForum.com
post #1 of 8 Old 01-16-2010, 03:30 PM Thread Starter
rixcj
rixcj's Avatar
1979 CJ5
OK...the next question of my restoration project is...
How much will I have to drop the rubber nubs (the things that attach to the frame, and hit the axle if it compresses too much), when adding a 2 1/2" suspension lift?
I know that I can jack up one end of the axle to see where things are when the shock fully compresses, but what's the distance that I want to leave before the shock DOES fully compress? Like 1 inch, or so?
Thanks.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #2 of 8 Old 01-16-2010, 04:40 PM
gmakra
Snubers are a moot point with a lift. Chances are you will never flex the axle that high.
gmakra is offline
post #3 of 8 Old 01-16-2010, 06:25 PM Thread Starter
rixcj
rixcj's Avatar
1979 CJ5
So, the shock won't collapse too far? I hope that's the case, I'll just put the new snubbers in the stock locations, with no drop.
Thanks!
Rich
rixcj is offline
post #4 of 8 Old 01-17-2010, 07:56 AM
ag4ever
1982 CJ8
The purpose of the stock snubber is to keep the axle out of the oil pan. It does not matter how much lift you put on it, the relationship between the snubber and the oil pan will stay the same.
ag4ever is offline
post #5 of 8 Old 01-17-2010, 08:13 AM
Mike Romain
Thanks!
Rich
Just make sure you get shocks that have enough travel, you don't want them to be the 'snubber', they will blow off fast that way.
Mike
Mike Romain is offline
post #6 of 8 Old 01-17-2010, 09:49 AM
afgd1
just replaced have friend with cj8 still has oem has 6 lift he has never hit it and he does 4 wheel ruff
afgd1 is offline
post #7 of 8 Old 01-17-2010, 10:53 AM Thread Starter
rixcj
rixcj's Avatar
1979 CJ5
I'm installing a 2.5" RE suspension kit, so I bought Rancho RS9000's to fit a CJ with a 2.5" lift.
Hopefully, it'll be OK.
Rich
rixcj is offline
post #8 of 8 Old 01-17-2010, 11:04 AM
Mike Romain
Rich
Should be, I also got the ranchos for a 2.5" lift and I stuff the tires big time some days:
Mike
Howell TBI Install: Tach and "Check Engine Light" question jatepper Jeep CJ Forum 10 07-19-2009 09:07 AM
quick "ball joint" question redcj576 Jeep CJ Forum 6 04-18-2009 06:28 PM
Narrowtrack rear axle with 2" spacers match up with a widetrack front axle? Blthomas Jeep CJ Forum 1 05-11-2007 08:25 PM
Power Steering Hose "O-RIng" Question? Mud Machine Jeep CJ Forum 2 02-04-2006 11:39 PM
Question "What makes a jeep a Renegade" bowlsy23 Jeep CJ Forum 9 07-18-2004 01:37 PM
