Axle help please - JeepForum.com
post #1 of 10 Old 08-19-2013, 07:20 AM Thread Starter
opdu12
1976 CJ7
Axle help please
I have a 1976 CJ7 V8 Automatic Quadratrac. The front and rear ring and pinion or differential need replaced. I was looking to just replace the entire axle instead of trying to rebuild the inside etc. I have found a set of matching front and back axles that were on a 76 CJ5 that are said to be narrow trac. I am being told the rear is offset to the right just like I need. In looking things up as best as I can it appears the 76 CJ7's did have the narrow trac? Is that correct or am I way off and these will never fit? Someone with a little more experience than I have please help me out here. Thank you!
opdu12 is offline
post #2 of 10 Old 08-19-2013, 07:33 AM
cardiffclimber
1981 CJ7
Wide track axles were not offered from the factory until '82. As long as you still have the stock axles, they should be narrow track.
"Rule #9.1: Never go anywhere without a jeep."
cardiffclimber is offline
post #3 of 10 Old 08-19-2013, 07:47 AM
CSP
The axles you found are a bolt in swap. Everything should be the same unless one of them happened to have the optional front disc brakes.
CSP is offline
post #4 of 10 Old 08-19-2013, 08:33 AM
LumpyGrits
You DON'T know the history of the axles your looking to buy(bent, twisted, left in the yard under water, etc)
You DO know the history of the axles that are on your Jeep.
Smart money would go the repair YOUR axles(seals are an easy r&r)and not take a gamble on 'un-known'.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #5 of 10 Old 08-19-2013, 08:43 AM
CSP
Meh, you take that same chance buying a used Jeep, so unless the PO has owned his CJ since new the risk isn't much different.
CSP is offline
post #6 of 10 Old 08-19-2013, 09:19 PM
John N
1981 CJ8
A '76 CJ-5 will not have an off-set rear like your Q'trac rear. They would be narrow track, though.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #7 of 10 Old 08-19-2013, 09:26 PM
80cj
80cj's Avatar
1980 CJ5
Exactly.
80cj is offline
post #8 of 10 Old 08-19-2013, 09:46 PM
MountainHound
1979 CJ7
He' right ---> http://www.jeeptech.com/models/cj-7.htm
Drum/Drum? If you were to swap in some bolt in axles, maybe look to upgrade.
1979 CJ7
2011 WK2
MountainHound is offline
post #9 of 10 Old 08-22-2013, 06:25 AM Thread Starter
opdu12
1976 CJ7
well once again jeep forum saved me from wasting money on a trip to find out the axles werent gonna work for me. These axles came off of a three speed transmission and the offset was to the left not the right like i need....and the search continues. So far the only place that Ive found that has a set is a jeep shop but I refuse to pay what they are asking, especially because they havnt even been gone through just pulled out of the CJ and selling them.
opdu12 is offline
post #10 of 10 Old 08-22-2013, 03:42 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Just out of curiosity, what exactly is wrong with your existing R+P's/diffs?
jeepdaddy2000 is offline
