Axle and Gears and mud O My - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Axle and Gears and mud O My
2001 - 2004 Jeep Grand Cherokee Power Window Regulator wit1990 - 1998 Jeep Cherokee Front Wheel Bearing & Hub AsEngo winches available at www.rockridge4wd.com! Free shipp
Unread 08-02-2010, 05:34 PM   #1
jkoch8819
Ok this is more of a question of personal opionion.. My Dana 30 front axle had nothing but mud and water in it... This is a new purchase so I really dont know the history and I made the mistake to just run it on the trails with out looking at it. Well the Pinion gear is now shot... the ring looks ok? but you can tell it has had water in it for awhile and no gear lube... Should I just put new lub in and replace the ring and pinion gear.. Or should I just replace the spider gears also.... they look ok but it has been running on mud instead of lube... What are your thoughts??? I was thinking of bitting the bullet and put an ARB in... Or I was looking at eaton electric locker but I dont know much about them...
All Jeeps are Jeeps, But built Jeeps are Real Jeeps... Round or Square
**The Only Thing Snow is good for is to check if the Jeep is Leaking**
jkoch8819 is offline   Reply With Quote
Unread 08-02-2010, 06:03 PM   #2
Trapshooter
Trapshooter's Avatar
Once you pull the parts you'll be able to do a better job of inspecting the hard facing on the gears. If there is any pitting at all, replace them.
Better yet, as you mentioned, now would be a good time it upgrade if the old budget can handle the expense. Having something more than just an open diff really comes in handy on the trail.
Good thing you discovered the problem before everything totally grenaded.
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build: http://www.jeepforum.com/forum/f8/tr...build-1338277/
Trapshooter is offline   Reply With Quote
Unread 08-02-2010, 06:09 PM   #3
crzdmnky
1977 CJ5
Or you can just keep that rearend around for parts, and go pick ya up another rearend off of craigslist for cheap, and get back to having fun...
crzdmnky is offline   Reply With Quote
Unread 08-03-2010, 12:59 PM   #4
jkoch8819
Why would I pick up a rear end when the front end is what broke??
Unread 08-03-2010, 01:00 PM   #5
jkoch8819
I guess I need to clean the mud out real good and see what I am up against... So what do you think is better? an ARB or eaton?
Unread 08-03-2010, 01:09 PM   #6
kickingprop
ARB would be better than Eaton I think... Also dont rule out the new Yukon Zip air locker. they are newer on the market but have been getting really good reviews from people running them. Also about $200 or so cheaper is nice also
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline   Reply With Quote
Unread 08-03-2010, 02:14 PM   #7
crzdmnky
1977 CJ5
LOL, its what they are called, rearends. Sorry i didnt make myself more clear. When I hear front end, I think 2 wheel drive.
Unread 08-03-2010, 02:25 PM   #8
CJ Chet
Don't forget to take care of your axle vent, sounds like a problem there.
Beer is the answer - it doesn't matter what the question is!
'86 CJ7, 265 CI, DUI, TF999, Borla, Weber, 4" BDS Lift.
'04 AEV RUBICON.
'00 TJ Sahara.
CJ Chet is offline   Reply With Quote
