Axle degree shims - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Axle degree shims
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 10-28-2015, 02:08 PM   #1
somedude922
1979 CJ7
Axle degree shims
Have stock width leaf spring in my 79 cj7. I ordered rubicon express 2.5" wide shims. Will they fit? I didn't see a 2" wide shim. Trying to correct caster angle.
somedude922 is offline   Reply With Quote Quick reply to this message
Unread 10-28-2015, 02:14 PM   #2
Renegade82
Renegade82's Avatar
1982 CJ7
No, they won't fit between the Ubolts. Warrior Products makes steel 2" wide shims. I know Quadratec sells them.
http://www.quadratec.com/products/16121_0907.htm
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is online now   Reply With Quote Quick reply to this message
Unread 10-28-2015, 10:58 PM   #3
John N
1981 CJ8
Be sure that whatever brand you buy, get steel shims. The aluminum ones are worthless, they crack, wear and cause the u-bolts to loosen up.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline   Reply With Quote Quick reply to this message
Unread 10-29-2015, 09:19 AM   #4
HackFabrication
1976 CJ5
I ordered these in 6* for my 76 CJ5:
http://www.wfoconcepts.com/cr/Axle-Shims/3225
"In the end...It's all Hack."
HackFabrication is offline   Reply With Quote Quick reply to this message
Unread 10-29-2015, 12:17 PM   #5
somedude922
1979 CJ7
Thanks! I'm going to order the 8* shims from WFO. Quadratrac only had up to 6* shims.
I'm sitting at -3* caster angle so 8* will work good.
Unread 10-29-2015, 03:32 PM   #6
HackFabrication
1976 CJ5
Wow! Are you sure that is a full 3 degrees negative and not .3 degrees?
Reason I'm asking, is my 76 CJ5 with a 2.5" BDS lift was at -.3 and -.6 caster without shims. The 6 degree shims will put me within the factory spec of 5-7 degrees positive caster.
Unread 10-29-2015, 03:45 PM   #7
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Yeah, I agree with Hack, something is amiss if your caster is a full 3 degrees negative.
Technically, lift springs alone should not change caster angle, if the eye-to-eye dimension of the springs is correct.
Longer eye-to-eye springs, like YJ springs, or longer shackles will change caster.
Matt
Matt1981CJ7 is online now   Reply With Quote Quick reply to this message
Unread 10-29-2015, 04:36 PM   #8
Renegade82
Renegade82's Avatar
1982 CJ7
Matt
Not necessarily true. It depends on how the arch is bent and if they provided a flat area at the spring perch. I've put on brand new Rough Country springs once and it changed the caster. Now granted, they were RC's.
Let's just say "when designed correctly, lift springs should not change caster".
Unread 10-29-2015, 04:39 PM   #9
Matt1981CJ7
1981 CJ7
That's a better way to phrase it.
Matt
Unread 11-03-2015, 09:35 AM   #10
somedude922
1979 CJ7
Sorry it took a bit to get back.... I haven't ordered any shims yet. Yes I checked the angle my self and it was -2.x. I didn't believe it either. Took it to an alignment shop and their printout was: image-3874984342.jpg So....I think I have a mildly bent drivers front spring. So would it throw caster off that much? I also have a CV shaft, would using shims cause me vibration? Granted this jeep hasn't seen much road time but I am wanting to flat tow it and the test tow was a nightmare. I turned right and the jeep went full turn left. I figured I would work on the caster angle first. Ball joints and most steering parts are in good order.
Unread 11-03-2015, 12:01 PM   #11
Fourtrail
1974 CJ6
Seeing the -3* caster and the fact that you said it had a CV shaft, then the correct way to fix the caster is to cut and turn the knuckles. You have the -3* because the axle has been modified/shimmed to get the pinion to point at the front output yoke to use a CV style drive shaft. Can you get a picture of the front suspension/axle so we can take a look to make a better informed guess?
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline   Reply With Quote Quick reply to this message
Unread 11-03-2015, 01:37 PM   #12
somedude922
1979 CJ7
I was incorrect. I do not have a CV shaft. It also appears this is not the stock angle either, which I knew but was hoping the shims might help. CUt and turn is not really an option at this time or the near future.....
Unread 11-03-2015, 01:38 PM   #13
somedude922
1979 CJ7
Unread 11-03-2015, 01:39 PM   #14
somedude922
1979 CJ7
Unread 11-03-2015, 01:56 PM   #15
CSP
Do you have long front shackles?
Are the shackles at the front of the front springs or the rear?
CSP is offline   Reply With Quote Quick reply to this message
