axle breather - JeepForum.com
post #1 of 9 Old 08-26-2013, 05:16 PM Thread Starter
Newbjeep
1972 CJ5
axle breather
Hi all i know its probably a dumb question but do i need to replace the little axle breather with a piece of tube on my dana 44 rear axle so that it can get water in it i thought i read some where that it wont let water in or oil out is that true
Newbjeep is offline
post #2 of 9 Old 08-26-2013, 05:30 PM
capt205
1983 CJ7
Morris 4x4 has them
capt205 is online now
post #3 of 9 Old 08-26-2013, 05:46 PM Thread Starter
Newbjeep
1972 CJ5
The question is do i need to swap the one i have for a tube running up away from where water will be or will the breather actually hold water out? Sorry if my post was confusing
Newbjeep is offline
post #4 of 9 Old 08-26-2013, 05:51 PM
WNC-84CJ7
Your tube should be high and dry. The breather is a vent, but I wouldn't rely on it to keep water out. Also, punctuation goes a long way my friend. I would recommend using it when possible.
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
-- Thomas Jefferson, 1 Thomas Jefferson Papers, 334
WNC-84CJ7 is offline
post #5 of 9 Old 08-26-2013, 05:56 PM Thread Starter
Newbjeep
1972 CJ5
Ok i will work on my grammar. Thank you for the info. Now all i need to do is run that tube and my rear axle is done. Thank you again for the info.
Newbjeep is offline
post #6 of 9 Old 08-26-2013, 06:04 PM
walkerhoundvm
1981 CJ8
This is just one reason I like this forum way more than pirate
walkerhoundvm is offline
post #7 of 9 Old 08-26-2013, 06:32 PM Thread Starter
Newbjeep
1972 CJ5
Oh and whats the torque specs for the u bolts and lug nuts?
Newbjeep is offline
post #8 of 9 Old 08-26-2013, 06:51 PM
LumpyGrits
Just run a line has high as you can, then loop it over 3-4 inches.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #9 of 9 Old 08-26-2013, 09:51 PM
82JeepCJ7
1982 CJ7
I use German torque.. Guten Tight!
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
