axle bearing install/removal - JeepForum.com
post #1 of 3 Old 01-21-2010, 07:10 PM Thread Starter
CJMONEYPIT
I pressed a new bearing onto the shaft of a D44 and it seems that it did not seat properly on the shoulder of the shaft, but it will not move any further. The new bearing is of a different design than the one that came off (single piece versus two piece), but the same style bearing went on the other shaft without much fuss (it was a Spicer, this one is a Timken). I verified that it is the correct bearing. Is it safe to assume that it is supposed to seat completely on the shoulder? Of course, I already had the other one installed, and I really don't want to yank it back out for comparison purposes. If it is not acceptable the way it is (at least 1/16 In. from being completely seated), how can I get it back off without cutting it off? I can't figure out how to configure my Harbor Freight shop press to get it off and I can't imagine cutting it off without destroying the new seal as well.
- 83 Scrambler, AMC 360, Edelbrock intake, Howell fuel injection, 32in. BFG MT, 2in. Superlift, stock axles.
- 85 CJ-10a, work in progress
CJMONEYPIT is offline
post #2 of 3 Old 01-21-2010, 07:58 PM
75*CJ
Not sure how to remove without cutting.....to install however, we heated the inner ring to get it to expand and it dropped right on where it belongs.
75*CJ is offline
post #3 of 3 Old 01-21-2010, 08:31 PM
80cj
80cj's Avatar
1980 CJ5
The old bearing came off in 2 pieces beacuse they are assembled as one piece to keep the works together in manufacture. They eventually come apart as you described. You should be able to remove the bearing in a press using a bearing separator. As I remember, I was able to.
Edit: Hmmm. On second thought, maybe I did cut the bearing off with a Dremel cutoff disc. Just make sure not to cut into the axle shaft. Cut into the bearing inner race then split it with a cold chisel.
80cj is offline
Front wheel bearing removal on 73 Cj5 ub2slo Jeep CJ Forum 0 01-23-2010 10:36 AM
bearing removal ksheffer08 Jeep CJ Forum 2 09-13-2009 11:00 PM
AMC 20 Axle Bearing Removal RetiredSERE Jeep CJ Forum 9 04-30-2009 05:55 AM
AMC 20 One Piece Axle Bearing Removal Tip... nickdz Jeep CJ Forum 3 01-15-2005 06:49 AM
axle, hub, removal for 1 piece install certifiablejeep Jeep CJ Forum 13 09-13-2003 02:40 PM
