AX-15 Flywheel - JeepForum.com
post #1 of 3 Old 03-04-2013, 09:32 PM Thread Starter
RenoF250
AX-15 Flywheel
I am working on putting an AX-15 in my CJ7 and I am wondering, can I use the 4.2s flywheel with the AX-15 flywheel/starter?
RenoF250 is offline
post #2 of 3 Old 03-04-2013, 10:04 PM
jeepwhore
The flywheel and starter have to be matched whichever you use. If you are putting MPFI on this jeep use the flywheel for the AX15 donor as the CPS reads the notches in the flywheel. I've read that the clutch and pressure plate should match the transmission but I'm not sure how compatible the 4.2L flywheel is with that set up.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline
post #3 of 3 Old 03-05-2013, 06:54 PM Thread Starter
RenoF250
I have a 4.0L I intend to use in the future but I am going to run the 4.2L for now. Sounds like I will need the 4.0 flywheel now then. I can use the starter from the 4.0l so that is no problem.
Thanks
RenoF250 is offline
