Awful sound when turning jeep off - JeepForum.com
post #1 of 10 Old 10-30-2009, 01:47 PM Thread Starter
Aduffy32
Whenever i turn my cj off after i have been exerting it a little, it almost sounds like its trying to start back up again. After about 4 seconds it sounds like pressure gets released then it stops. Its sort of scary. Any ideas? thanks
Aduffy32 is offline
post #2 of 10 Old 10-30-2009, 03:06 PM
Fatman
Fatman's Avatar
2008 CJ7
Based upon the amount on information you have provided us about your Jeep's setup ..... motor, trany, modifications ?
No idea!
Help us, so we might help you.
Thread Links:
Fatman is offline
post #3 of 10 Old 10-30-2009, 03:13 PM Thread Starter
Aduffy32
The motor has been rebuilt by performance powertrain about 5,000 miles ago , and I believe I have a stock 5 spd transmission. I also have a MSD ignition box, and an upgraded clifford carb, and an electric fuel pump. Sory about the lack of information before
Aduffy32 is offline
post #4 of 10 Old 10-30-2009, 03:28 PM
Fatman
Fatman's Avatar
2008 CJ7
Might want to check for air leaks around the manifold.
Also, with electric fuel pumps, it's nice to run a switch into the relay so you can shut off fuel before you kill the ignition. I'd also want a kill switch on the MSD, but that's more of a security thing with me.
Still not sure what motor your running, but some ideas for you to chase.
Al least you're not dieseling.
Thread Links:
Fatman is offline
post #5 of 10 Old 10-30-2009, 03:42 PM
Scuter83
1974 CJ5
I had something similar in my stock '74 CJ5 with the 258 in it. I lowered my idle speed and re-set the timing. I also added in the vacuum advance. That has seemed to fix my problems.
To me it does sound like you are dieseling. To me it sounds like you are firing little by little still after you shut the key off and then finally it dies and backfires a little through the carb. Next time you shut it off, try to pull the choke as you shut it off and see if it doesn't do it. That used to work for me some, not really a fix, but then I knew it was something with the carb. I attributed it to my high idle and incorrect timing causing fuel to get sucked out of the carb and hot spots in the cylinder to fire the fuel off.
Scott
Scuter83 is offline
post #6 of 10 Old 10-30-2009, 03:43 PM
CSP
Sounds like run-on to me. It's either a problem with timing that's too far advanced or hot spots in the cylinders.
CSP is offline
post #7 of 10 Old 10-30-2009, 03:45 PM
BioTex
Fatman,
Why do you say he's not dieseling? That is what it sounds like to me. Also known as run-on. If I have my timing off, it will diesel. Sounds just like it is trying to stay running. The hotter the engine, the more it does it. I tweaked my timing, and it completely cured it. Engine was a 258, and recently rebuild just like OP's.
Higher octane gas will help alot, especially with a lot of advance.
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20.
06' TJ Rubicon, 4" R.C. springs, BFG/AT 35s M.C. 6" fenders, rockers and surrounds, Currie front & rear adj. tracbars, tattons DC rear shaft, adj. upper - lower CA's. Bilstein 5100's
Current project. Stroker/FI ?
1990 MJ Comanche 4.0L AX15/np231
BioTex is offline
post #8 of 10 Old 10-30-2009, 03:49 PM
Jeepican
1976 CJ5
Maybe your hampsters have bad gas????
1976 CJ5 - 232 I6, MC2100, YJ Booster, Front disc conv, 2.5" BDS, 1" Body Lift, .5" lift Daystar Shackles, 33 x 10.50 BF KM2, Twin Stick
"Oh, you're just full of fun today, aren't you? Why don't we go up to the old people's home and wax the steps?"
-Barney Fife-
Jeepican is offline
post #9 of 10 Old 10-30-2009, 03:57 PM
Fatman
Fatman's Avatar
2008 CJ7
Dieseling sounds more like dead chug or run-on. Much like you see when you have an automatic trans.
I interpreted his "Awful sound" as post ignition detonation. Air leak and un-burnt fuel.
Agree timing advance is playing a role here.
Thread Links:
Fatman is offline
post #10 of 10 Old 10-30-2009, 04:26 PM
Mike Romain
I would want some more details of the noise and 'run on' maybe before guessing.
Mike
Mike Romain is offline
Body is Back From Paint Everyone it is turning into a Tigger Jeep finally with Picts Tigger01 Jeep CJ Forum 52 10-11-2009 11:33 PM
Normal binding sound when turning in 4wd CrazyHorse6 Jeep CJ Forum 4 01-31-2009 09:30 PM
Jeep Turning Radius (Jeep Turns To The LEFT Great, Not So Much To The RIGHT) Military Jeeper Jeep CJ Forum 8 02-27-2008 11:08 AM
It's a sad, miserable, awful day. gtrpup2 Jeep CJ Forum 24 05-16-2007 07:25 PM
Jeep shakes when turning it off!! Scuter83 Jeep CJ Forum 2 05-09-2007 02:04 PM
