Autometer tach in a cj5 - JeepForum.com
post #1 of 4 Old 03-05-2013, 10:26 AM Thread Starter
blaylock6502
I put an autometer ultralight 2 in my 74 cj5. It is very jumpy and inaccurate. I contacted autometer and they said to put a 10k ohm .5 watt resistor inline with the signal wire to try to buffer some of the noise. I plan to do this was just curious if anyone had run into the same thing??
blaylock6502 is offline
post #2 of 4 Old 03-05-2013, 11:29 AM
OleBlue73
1973 CJ5
Yes. It's due to the electrical interference (laymen's terms) given off by the plug wires. If you have a radio, you are probably experiencing speaker hum too. You can also swap to a higher suppression plug wire set, but the resistor is the cheaper route.
1973 CJ5, 304, T15, D20
2009 JKU, Rubicon
2005 TJ, X, 4.0, 6 speed
OleBlue73 is offline
post #3 of 4 Old 03-05-2013, 11:50 AM Thread Starter
blaylock6502
Thanks a ton! I am a gm tech and have a ton of 10k 1/4 watt resistor will that work or do I need to find a 1/2 watt??
post #4 of 4 Old 03-05-2013, 12:00 PM
OleBlue73
1973 CJ5
You could try what you have and if it doesn't work, find a 1/2 watt.
2009 JKU, Rubicon
