Automatic Transmission missing parts - JeepForum.com
post #1 of 6 Old 04-25-2010, 02:52 PM Thread Starter
naviacarlos
1982 CJ7
Hello
I have a jeep CJ7 model 82 with six cylinder engine (258) and automatic transmission which is being rebuilt for almost 1 year. It is my toy. Howvever, the car has a problem with the automatic transmission: The jeep does not have power, the automic transmission is not working properly. The mechanical says that the piece which conects the carburator with the transmission has being changed. I found in a jeep manual parts, chapter linkage, automatic transmission throtlle valve 1981-86 CJ-5,6,7,8 scrambler figure 14-2100,the following pieces missing in my car:
Item 2: ROD, Part Number J324 0357
Item 11: BUSHING, Part Number J322 0125
Item 18: SPRING, Part Number J319 6286
Item 20: PIN, Hitch, Part Number J400 5122
Item 19: BOLT, Part Number S943 2476
Item 24: WASHER, Part Number J400 1085
Item 22: LINK, Part Number
Item 21: SPACER, Part Number J322 3656
Item 23: CLAMP, Part Number
I need the parts new or used to finish my car.
I appreciate your help on this.
naviacarlos is offline
post #2 of 6 Old 04-25-2010, 03:29 PM
ctm
much easier to convert to a cable instead of trying to find all those OEM linkage parts:
Lokar KD-2727HT Lokar Custom Fit Stainless Steel Transmission Kickdown Cable Kits
there is a little modification to get the brackets to fit.
ctm is offline
post #3 of 6 Old 04-25-2010, 03:58 PM
VACJ7
VACJ7's Avatar
Are you looking for items from this diagram? I may have some of this.
VACJ7 is offline
post #4 of 6 Old 04-25-2010, 04:26 PM
CJ Chet
I have that Lokar cable on mine. It's alot better than the OEM linkage.
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #5 of 6 Old 04-26-2010, 06:32 PM Thread Starter
naviacarlos
1982 CJ7
Yes!!!
I need the parts from six cylinder. Which pieces do you have?
thanks
Carlos
post #6 of 6 Old 04-26-2010, 06:33 PM Thread Starter
naviacarlos
1982 CJ7
Do you have any idea how is the installation?
thks.
1982 , automatic transmission , cj7 , linkage , rod
NEED HELP to ID my Automatic Transmission theplasterman Jeep CJ Forum 8 09-27-2010 08:39 PM
Missing heater parts.... Dborns Jeep CJ Forum 2 01-26-2010 07:50 PM
NEED HELP to ID my Automatic Transmission theplasterman Jeep CJ Forum 1 08-10-2009 09:26 PM
Automatic Transmission 1958 CJ7 kbuss32 Jeep CJ Forum 5 02-05-2008 02:59 PM
Handbrake Parts Missing airbud Jeep CJ Forum 1 10-21-2007 02:08 PM
