Automatic transmission input shafts - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Automatic transmission input shafts
ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep Grand Cherokee Tie Rods & Adjusting Sleeves
Unread 03-01-2015, 09:38 PM   #1
kjonesie
1983 CJ7
I have 2 (supposedly the same) Torqueflite 904 transmissions. The input shafts are different. Can anyone explain0301151632.jpg
0301151633.jpg?
kjonesie is offline   Reply With Quote Quick reply to this message
Unread 03-02-2015, 06:33 AM   #2
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Are you sure one isn't the 727?
"A lockup 727 transmission has about 5/8" of the end of the smaller input shaft machined smooth. "
http://www.allpar.com/mopar/torqueflite.html
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 03-02-2015, 07:39 AM   #3
kjonesie
1983 CJ7
Matt
The one with the tapered shaft came out of my 83 CJ7. Would it have been a 727?
Unread 03-02-2015, 09:35 AM   #4
Matt1981CJ7
1981 CJ7
I think AMC did use the 727, but not on '80s CJs.
The TF999 was used on all I6 and V8 CJs from '80-'86. The TF904 was used with the 4-banger CJs.
I guess it's possible the 727 could have been swapped into the '83 CJ7.
Matt
Unread 03-02-2015, 09:53 AM   #5
kjonesie
1983 CJ7
When I bought my torque converter, I got one for the 9 series trannsmissions. It was only a guess on my part that it is a 904.
Unread 03-02-2015, 09:55 AM   #6
lucdog
lucdog's Avatar
1980 CJ5
I think AMC did use the 727, but not on '80s CJs. The TF999 was used on all I6 and V8 CJs from '80-'86. The TF904 was used with the 4-banger CJs. I guess it's possible the 727 could have been swapped into the '83 CJ7. Matt
727 in FSJ's. Unless the CJ is lifted,4" or more, there would be interference issues with the front drive shaft. (727)
The easiest way to ID a tranny is to google tranny pan identification.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is online now   Reply With Quote Quick reply to this message
Unread 03-03-2015, 06:18 AM   #7
ctm
The first pic is a lock up trans. There are 904 and 999 lock ups out there. I have a 999 lock up in a 84 CJ7.
ctm is offline   Reply With Quote Quick reply to this message
Unread 03-03-2015, 11:31 AM   #8
kjonesie
1983 CJ7
Could you explain what a lock up is
Unread 03-03-2015, 12:31 PM   #9
CSP
The torque convertor will lock up at certain speeds so there is 100% power transmission. A non-lockup convertor will always have some slippage.
CSP is online now   Reply With Quote Quick reply to this message
