Auto Trans Shifter - JeepForum.com
post #1 of 6 Old 01-08-2010, 10:53 AM Thread Starter
lbijeep
1980 CJ7
Auto Trans Shifter
Anyone have any suggestions on what types / brands of Auto trans shifters would #1- Work or #2 Look good on an 80 CJ7? . I am not going to do a steering column shifter since I already have an existing hole in the floor where I ripped the SR-4 from. I see a few racing / aftermarket shifters and housings that are floor mounted, but they seem to be more designed with the shift pattern on the knob, which I think won't work well for low light or driver's other than me. I was hoping to find something that resembled a set up in a Cherokee or Laredo that had the gear indicator on the box (lighted) and the actual shifter was just the metal piece.
I know there is a separate post for photos only, but thought I would start here Thanks
lbijeep is offline
post #2 of 6 Old 01-08-2010, 10:58 AM
dr_hunt
1976 CJ7
I tried some of the B&M street rod shifters with the long shifter handle, but with my console I had to mount it too far forward and it would hit the dash when in park. So, I build a pedestal out of solid oak, screwed it to the floor and mounted a B&M z gate shifter on top of that. Looks good, and the shifter is the right height and doesn't hit the dash when in park.
dr_hunt is offline
post #3 of 6 Old 01-08-2010, 12:08 PM
CJ Chet
I use a B&M Megashifter (ratchet). Works quite well for me. I picked up a new tranny hump cover, blank with no shifter hole, to make a neater install.
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #4 of 6 Old 01-08-2010, 12:24 PM
kickingprop
I'm really pleased with my Lokar shifter...
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline
post #5 of 6 Old 01-08-2010, 04:36 PM
CJ Chet
I think if I were to do it again, I'd get an Art Carr.
'86 CJ7
'04 AEV RUBICON
CJ Chet is offline
post #6 of 6 Old 01-09-2010, 02:40 AM
OldSailor
1977 CJ7
I prefer ratchet shifters for my off-road vehicles. When my CJ7 had a steel body, I had a B&M Quicksilver shifter for the TF999 tranny and it worked fine. When I replaced the (rusted) steel body with a fiberglass body, I didn't want to use the Quicksilver shifter because it switches from normal mode to ratchet mode by lifting up on the shifter handle. In my mind, that would tend to put a lot of repetitive stress on the fiberglass floor. So I switched to a B&M Megashifter (which uses a trigger t-bar) and have been very happy with it. My neighbor has a early 90s Chevy pickup with a 700-R4 tranny and he recently installed a B&M Megashifter in it and he's pleased with it.
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc.
OldSailor is offline
Auto Trans Column Shifter rrtex1 Jeep CJ Forum 2 12-16-2009 11:20 AM
84 CJ-7 Loose Shifter-which trans??? andrewferin Jeep CJ Forum 2 04-12-2009 08:51 PM
CJ5 trans loose shifter foxracer677 Jeep CJ Forum 3 01-31-2009 05:13 PM
trans shifter pics sefh Jeep CJ Forum 2 11-19-2006 05:54 PM
Auto Trans Shifter. sefh Jeep CJ Forum 6 09-18-2006 02:28 PM
