Auto Trans Column Shifter - JeepForum.com
post #1 of 3 Old 12-16-2009, 10:08 AM Thread Starter
rrtex1
1981 CJ7
Replaced my trans fluid and filter this past weekend and tried to adjust the fill tube from top as it was behind the motor. I think I may have broke the tube.
Shifter on column is now hard to move, does this linkage go anywhere near the trans full tube? Why would all of the sudden the shifter be hard to move?
Round Rock, Texas
1981 CJ7 AMC304
rrtex1 is offline
post #2 of 3 Old 12-16-2009, 10:31 AM
John N
1981 CJ8
The fill tube is on the right side, the shift linkage is all on the left side. There is no connection between them. I don't see how messing with the fill tube could do what you're describing. Follow the linkage down from the column, check the pivot points and lube them. Some of the plastic/nylon bushings are probably trashed, too.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #3 of 3 Old 12-16-2009, 11:20 AM
scooter
1982 CJ7
Make sure the roll pin that goes thru the chrome shift arm didnt slide outta the cast section on the column. Mine does it occasionally and makes for some funky shifting.
scooter is offline
Auto Trans Shifter lbijeep Jeep CJ Forum 5 01-09-2010 02:40 AM
auto column shifter cable(linkage) twokids Jeep CJ Forum 6 02-21-2008 06:02 PM
column shifter to floor shifter TJbino4 Jeep CJ Forum 0 09-14-2007 06:25 AM
Auto Trans Shifter. sefh Jeep CJ Forum 6 09-18-2006 02:28 PM
steering column with automatic shifter clegger Jeep CJ Forum 4 07-06-2002 08:55 PM
