Auto Floor Shifter - Page 2 - JeepForum.com
post #16 of 24 Old 06-04-2013, 01:37 PM
bigblockyj
Shifter
Check out Art Carr/ Winters shifter...cool as 'ell!
bigblockyj is offline
post #17 of 24 Old 06-05-2013, 06:04 AM
cjjon7
1983 CJ7
Originally Posted by baldfatdad View Post
I mounted mine to the trany. Used the bolts where the tail shaft meets the main trans body.
Now you.did this with a 727 and scout II shifter?
cjjon7 is offline
post #18 of 24 Old 06-05-2013, 06:38 AM
CJ Chet
Originally Posted by sevenlitre2002 View Post
Yep, I have an Art Carr in my CJ-7.
I've had 2 different B&M shifters, and so far, I prefer the Art Carr.
I did file off one of the tabs, so I can go directly from D to R
If I were to do it again I'd get the Carr just for that reason. I love the idea of being able to slap from D to R.
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #19 of 24 Old 06-05-2013, 06:46 AM
lucdog
lucdog's Avatar
1980 CJ5
Does it look like this one, or do you have more parts? Some pictures might help.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #20 of 24 Old 06-05-2013, 07:15 AM
cjjon7
1983 CJ7
Yeah looks just like that and I have a green plastic bezel to make it look niceee
cjjon7 is offline
post #21 of 24 Old 06-05-2013, 07:42 AM
lucdog
lucdog's Avatar
1980 CJ5
A couple of other things to think about.
1.) knob height when installed.this will determine if a box needs to be made that sits above the tub.
2.) clearance between the tranny and tub, if your going to mount the bottom part underneath.
3.) cable operated of a solid rod, from a quick google looks like cable was OEM
4.) do you have the the proper hardware to mount the cable securely to the tranny. The 2 B&M shifters I have included different brackets for different trannys.
From the picture I posted it appears the mounting would need to be flat, so the shifter lever sits straight up and down.
And you said you need a new plate for the hole in the tub, correct?
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #22 of 24 Old 06-05-2013, 08:02 AM
cjjon7
1983 CJ7
That's is correct, will need a new tunnel cover blank to cut some custom holes in.
The shifter setup I got was used with a 727 in the scout so although the cable is a bit stiff, its all mounted up properly.
Having sat the body on 2 inch pucks, there will probably be enough room under there for mounting, I still need to climb in the Jeep and see.
Got a really cool OEM floor cover/p-r-d-1-2 indicator with the shifter... its of green and brown so matches the Jeep awesome
cjjon7 is offline
post #23 of 24 Old 06-05-2013, 08:48 AM
lucdog
lucdog's Avatar
1980 CJ5
I would get some 16 gauge steel, and make the plate. Make a cardboard pattern for the size and holes, and transfer the pattern to the plate.
Remember, you don't want any sharp bends in the cable. A big loop is best. The cable needs to come straight from the shifter and start the loop. The cable may end up lying on the tranny/TC, I would protect it with whatever hose fits the I'd of the cable. Garden hose may work, split it from end to end and use some zip ties to hold it on.
When installing the cover on the tub I would use 1/4" bolts with a fender washer on the glass side, ( maybe 2 depending on the thickness of the washer.)
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #24 of 24 Old 06-05-2013, 08:57 AM
cjjon7
1983 CJ7
Bill,
I pre drilled holes in the tub and crimped riv-nuts around the perimeter, in the holes. I think I will just make my own plate, beats paying 50$ for one on the internet
cjjon7 is offline
Floor Shifter-Auto Rollbar Jeep CJ Forum 3 04-27-2009 10:25 AM
Switching from column shifter to floor StewartCJ7 Jeep CJ Forum 4 09-12-2008 08:21 AM
column shifter to floor shifter TJbino4 Jeep CJ Forum 0 09-14-2007 05:25 AM
Floor shifter BLS33 Jeep CJ Forum 11 10-23-2006 02:02 PM
automatic floor shifter tolobill Jeep CJ Forum 4 04-05-2005 08:25 PM
