Ashley's New Ride - '80 CJ7 Laredo 304 Auto - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Ashley's New Ride - '80 CJ7 Laredo 304 Auto
Nitro Gear Packages Now Available at Rockridge 4wdJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFThe ULTIMATE "Selectable" Locker System! Brough
Unread 11-24-2012, 09:39 PM   #1
Rollbar
1984 CJ8
Ashley's new Ride
http://www.youtube.com/watch?feature...&v=bwxil7Kjp7U
Ashley's Cam Question Thread - http://www.jeepforum.com/forum/f8/ca...-304-a-1560268
Project CJ8 Build Gallery <----Click
CJ8 Build Thread<---- Click
Rollbar is offline   Reply With Quote Quick reply to this message
Unread 11-25-2012, 02:29 PM   #2
dslywalker
1983 CJ7
SWEET.You'll have to put it in the Stock looking CJ thread
Jeep Naked
Put some color in your Cheeks
dslywalker is offline   Reply With Quote Quick reply to this message
Unread 11-25-2012, 03:03 PM   #3
Rollbar
1984 CJ8
I have two ore stock, one of those is a CJ8
Unread 11-26-2012, 09:32 PM   #4
PavementPounder
Cool as Ice...
PavementPounder's Avatar
Dipstick tube: Drop oil pan and tap the exposed part in the crankcase upward from the bottom. Its just a press-fit.
You might be able to grab it from the top with a screw extractor.
This is how NAXJA Midwest Chapter elected officials like to treat their resident users and former multi-year supporters.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline   Reply With Quote Quick reply to this message
Unread 11-26-2012, 10:35 PM   #5
Rollbar
1984 CJ8
Thanks, I'll look a little closer and w/a flash light to see what I can see/to verify if any of the tube is sticking up.
Thanks for the tip,
Jim
Unread 12-23-2012, 04:14 PM   #6
Rollbar
1984 CJ8
I was looking at the frame, and the frame is ripped by both upper shock mounts (front). We are going to weld it this week.
I can't remember the Ford part number for shock mounts, does anyone know it and or the right size. If not then I need to order some factory stock ones.
Thanks,
Jim
Unread 12-25-2012, 10:25 AM   #7
MrBeast
1980 CJ7
Jim check out Parts Mike Tell him you need the 88 Ford F-250 shock towers, he will get you hooked up and his price is pretty reasonable and he is a great guy to deal with.
I installed them on mine with a MORE shackle reversal, YJ 2 1/2" lift springs and OME shackles, I am really really happy with the setup no death wobble what so ever, it is super steady on the road.
I'll be watching to see how it turns out. I just swapped a 304 and NV4500 into mine, really anxious to have it running.
[I]"He used to be a pretty nice feller, now he's a welder"[/I]
[URL="http://www.jeepforum.com/forum/f22/1980-cj7-first-jeep-build-1243620/"]80 CJ7 "The Kraken" - a project 25 years in the making[/URL] AMC 304 V8, NV4500, Dana 300, Dana 44, 9 inch, M.O.R.E. SRS, YJ tub.
AT3 US Navy 1999-2003
[B][SIZE="3"] Cum catapultae proscriptae erunt tum soli proscript catapultas habebunt[/SIZE][/B]
[SIZE="1"](When catapults are outlawed, only outlaws will have catapults)[/SIZE]
MrBeast is offline   Reply With Quote Quick reply to this message
Unread 12-25-2012, 04:24 PM   #8
Rollbar
1984 CJ8
Thanks for the info.
Looks like she is not buying a lift kit at first so I will get the standard CJ shock towers then buy the longer ones w/shocks. No since to get the longer one right now.
Unread 12-27-2012, 04:47 PM   #9
Rollbar
1984 CJ8
Ok found the high idle. Fixed the timing and crossed wires and she runs great/idles great.
Now I have a lot of lifter noise.
*Does anyone know if the 1980 304 has adjustable valves/lash?
Thanks,
Jim
Unread 12-27-2012, 04:53 PM   #10
Rollbar
1984 CJ8
Question. with this older motor (1980/304) do I have to run some oil w/leaded deposit/zink (not sure if I got it right but).
Someone told me it would help and to use Rotella T.
Thanks,
Jim
Unread 12-27-2012, 05:47 PM   #11
roboto65
1976 CJ5
No unleaded will be fine and oil well lets not get that started LOL Pretty sure the valve lash is set and not adustable should be hydralic lifters you might try runining some seafoam thru the oil might clean things up but I would not expect much.
Was the compression low?
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline   Reply With Quote Quick reply to this message
Unread 12-27-2012, 06:35 PM   #12
lucdog
lucdog's Avatar
1980 CJ5
Valve lash is not adjustable . Lead additive is not needed in a engine that was Designed for unleaded fuel, 1980 falls into that Category.
1957 WILLYS pickup, needs work.
1973 J 4000,
1978 CJ7 DD.
1979 CJ7 360, TH400/Quadratrac trail Jeep.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7 pretty weekend and sometimes to work Driver in the summer, My first rebuild, if the Q-trac and 5 are broke, this one is the one to take. its just as capable as the other 2, except nice paint.
1984 Grand Wagoneer, 1 ton axles, great 360/727, and a big a$& tree fell on it .
1989 YJ the CJ to YJ conversion.
2005 TJ Rubicon.
2011 Grand Cherokee Laredo 4x4, Mrs. LUCDOG's DD.
Lots of parts not for sale, i'm a hoarder.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 12-27-2012, 06:42 PM   #13
MrBeast
1980 CJ7
I personally am a big fan of marvel mystery oil, I always run a quart through any second hand motor I inherit just to make sure it is good and cleaned out for about 3000 miles. Doing this has always served me well and I have had it unstick stuck lifters and free up all kinds of other issues.
You should be able to run this motor on 87 Octane, I also highly recommend going to an MSD 6AL box and Blaster II coil the stock 32 year old ignition is not exactly going to be a spring chicken any more, and even if it is working, it may not be working as good as it could be and will cause poor fuel mileage.
Unread 12-27-2012, 07:28 PM   #14
Rollbar
1984 CJ8
Thank you all.
I have not had time today to check the compression and thanks for the info on the valves.
She will be changing the oil this weekend and I will add a qt of MMOil. I usually add a 1/2 qt to all my 258 CID oil changes. She is gonna add a qt of MMOil and let it get hot then change the oil/filter.
As for the ignition, ya your right/spring chicken in time I guess.
Thanks again,
Unread 12-27-2012, 07:29 PM   #15
Rollbar
1984 CJ8
