Ashley's New Ride - '80 CJ7 Laredo 304 Auto - Page 4 - JeepForum.com
post #46 of 375 Old 07-20-2013, 11:08 PM Thread Starter
Rollbar
1984 CJ8
She tried real hard to get the rod out but it felt like it was in a "Z".
<----Click
<---- Click
Rollbar is offline
post #47 of 375 Old 07-28-2013, 11:31 PM Thread Starter
Rollbar
1984 CJ8
Well the beginning of open heart surgery on the Beast as Peach called it.
Ashley has decided to go w/a short block rebuild and she will learn to do the valve job. Great experience.
Look ma, no gloves.
<----Click
<---- Click
Rollbar is offline
post #48 of 375 Old 07-28-2013, 11:35 PM Thread Starter
Rollbar
1984 CJ8
Ashley is rebuilding her 304 in a stock configuration but adding:
Edelbrock 4bbl intake and 1406 4bbl carb.
Someone mentioned that she should put a RV cam in the 304 and I don't know whether or not I should recommend it to her. They also told me by her using the intake/carb it will help it breath.
Question, what would be the recommended route her for her to go?
Thanks,
Jim
http://www.jeepforum.com/forum/f8/as...50/index4.html
<----Click
<---- Click
Rollbar is offline
post #49 of 375 Old 08-02-2013, 03:24 PM Thread Starter
Rollbar
1984 CJ8
<----Click
<---- Click
Rollbar is offline
post #50 of 375 Old 08-02-2013, 03:25 PM Thread Starter
Rollbar
1984 CJ8
<----Click
<---- Click
Rollbar is offline
post #51 of 375 Old 08-02-2013, 03:25 PM Thread Starter
Rollbar
1984 CJ8
Cam Gear question.
<----Click
<---- Click
Rollbar is offline
post #52 of 375 Old 08-02-2013, 03:38 PM
lucdog
lucdog's Avatar
1980 CJ5
No preload on the gear, just a torque value. It's been a while, but, I believe the gear and fuel pump eccentric use a woodruff key, as does the cam gear.
I would get a matched set of gears, espically if you can see wear.
One other note, it has to do with the new cam gear. You will see, after removing the cam gear where to oil comes from for lubeing the chain and other parts. Pay particular attention on the new gear to ensure there isn't any cast flashing where the oil passes thru the center bore.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #53 of 375 Old 08-02-2013, 04:10 PM Thread Starter
Rollbar
1984 CJ8
Thank you,
Jim
<----Click
<---- Click
Rollbar is offline
post #54 of 375 Old 08-02-2013, 04:22 PM
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by Rollbar
Thank you,
Jim
No problem, and thanks to you.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #55 of 375 Old 08-02-2013, 07:48 PM Thread Starter
Rollbar
1984 CJ8
Question.
Is this where the fuel pump rides - correct?
If so, look at this. It has a grove in it and if the new reman engine doesn't have one then I have to get one.
Is it presses on or ?
Thanks,
Jim
<----Click
<---- Click
Rollbar is offline
post #56 of 375 Old 08-02-2013, 08:08 PM
lucdog
lucdog's Avatar
1980 CJ5
Yes, that is the fuel pump eccrencit
Looks like a lack of oil, the arm of the fuel pump is suspose to ride in the middle, was the arm on the pump Perpendicular to the mounting surface. Start your search for one now. I had a hard time locating one.
Also, after removing the timing gear, look for anything that could have blocked the oil path. I found gunk in mine when I changed the timing set. I'm just Curious.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #57 of 375 Old 08-02-2013, 08:18 PM Thread Starter
Rollbar
1984 CJ8
Thanks. Hopefully the engine from www.sandjengines.com will have on eon the cam. I need to ask them.
Keep you posted.
And thanks,
Jim
<----Click
<---- Click
Rollbar is offline
post #58 of 375 Old 08-03-2013, 09:33 PM Thread Starter
Rollbar
1984 CJ8
Well, Ashley is on the fence about this S&J engine. After she has thought about it and checking out the fine details of the warranty and shipp/core she just might use the 258 I have w/90k on it that is torn apart.
We will see.
<----Click
<---- Click
Rollbar is offline
post #59 of 375 Old 08-17-2013, 05:09 PM Thread Starter
Rollbar
1984 CJ8
Ok Ashley was working on her cyl head and she found this. By the time she gets new valves (they are bent) and new seats she can get heads.
<----Click
<---- Click
Rollbar is offline
post #60 of 375 Old 08-17-2013, 05:10 PM Thread Starter
Rollbar
1984 CJ8
Need some 304 head that will fit her 1980 CJ/304.
Jim
<----Click
<---- Click
Rollbar is offline
