Applying bed liner to the tub, masking for drains? - JeepForum.com
post #1 of 5 Old 10-21-2013, 06:24 PM Thread Starter
cj5russ
cj5russ's Avatar
1976 CJ5
Hey guys when you all bed liner your tub, what do you do about the drain holes, does the bed liner make it too thick to put the plugs in? Do you mask? Or will the plugs fit even over bed liner? Thanks.
cj5russ is offline
post #2 of 5 Old 10-21-2013, 06:28 PM
seabass1858
1983 CJ7
on my old tj i stuffed the holes with paper towls and had linex do it and i just pulled the paper towels out and put the plugs in. I dont know if it was proper but i had a nice clean hole but i would think that they would fit either way IMHO.
seabass1858 is offline
post #3 of 5 Old 10-21-2013, 06:33 PM
WindKnot
1977 CJ7
There's more than enough flex in the plugs to handle the material.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is online now
post #4 of 5 Old 10-21-2013, 07:29 PM
KMD
1976 CJ7
Used foam ear plugs for all the bolt holes. Did not worry about the drain holes and plugs still fit.
KMD is offline
post #5 of 5 Old 10-21-2013, 09:47 PM
Spieg8
1984 CJ8
Don't know how the plugs fit after the bed liner... I never plug the drain holes (like the extra ventilation and enjoy watching the road go by under the Jeep ).
Spieg8 is offline
