anything wrong w/ running a CJ in front wheel drive only? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > anything wrong w/ running a CJ in front wheel drive only?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6
Unread 01-06-2009, 12:02 PM   #1
cbushrun
1981 CJ5
I need to get my CJ5 to a shop for them to correct the rear pinion angle and I dont want to drive it w/ the vibration, or pay to have it towed (Im cheap). Is there any problems w/ removing the rear driveline, putting it in 4WD and driving it by powering the front wheels only?
I have 8 degree shims right now, and they arent enough with the new lift. I want to do away w/ the shims and have the axle mounts cut off and rewelded at the right angle.
Any other ideas for a temporary fix to get it to the shop?? Its about 15 miles from my house.
Thanks guys!!
81 CJ5 - 4.3 carb'd - TH350 - Dana 300 - 2.5" lift w/ 31"s
cbushrun is offline   Reply With Quote
Unread 01-06-2009, 12:04 PM   #2
JoonHoss
2011 JK Wrangler
go slow, and take it easy. not the best method, but it should work just fine.
however, this would be a good time to buy/use a tow bar/lights, that way you'd always have them if you ever needed them!
Hoss
It's hard to say no to yoo-hoo, the name literally beckons...
Don't mind me, I'm just another FNG around here...
JoonHoss is offline   Reply With Quote
Unread 01-06-2009, 12:07 PM   #3
jeepwrangler97
I knew a kid, not a very bright kid, but I knew him and he drove his XJ as front wheel drive for a couple of months until he got a new rear drive shaft and nothing broke. I'm still not sure if it's okay, but nothing on his broke
jeepwrangler97 is offline   Reply With Quote
Unread 01-06-2009, 01:01 PM   #4
Squatch
1976 CJ5
It should be fine, but your rear R&P will still be meshing so as long as they dont chew eachother up
Squatch is offline   Reply With Quote
Unread 01-06-2009, 01:17 PM   #5
neals80
1980 CJ7
been there done that..take it easy like mentioned
Neal Trombley
1980 CJ 7
SW FLORIDA
IF I WANTED A HUMMER I WOULD HAVE CALLED YOUR GIRLFRIEND!!
neals80 is offline   Reply With Quote
Unread 01-06-2009, 02:05 PM   #6
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
I had to do it when I broke my rear driveshaft. Drove about 22 miles home and no problems, but as mentioned take it easy. I don't think I went more the 30 or 35 the whole way.
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline   Reply With Quote
Unread 01-06-2009, 02:37 PM   #7
Bard
I will say this on this one. I have and would driven my Jeep over 200 miles with just the front driveshaft. Take the rear out and run in 4HI. No problems at all at highway speeds, just remember, safety is key.
If your differential is locked in the front, unlock a hub and just go easy. If unlocked diff, lock both hubs and treat it as a front wheel drive vehicle.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline   Reply With Quote
Unread 01-06-2009, 03:30 PM   #8
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
I also have driven highway at 60+/- for over an hour to get home on front wheel drive and for a couple weeks after with no issues at all.
Just don't give it too much gas when the wheels are tuned hard, you have universals up there, not CV's.
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Unread 01-06-2009, 03:46 PM   #9
Renegade79
2010 JK Wrangler
i had to do this once out of necessity when a rear universal joint busted on me. it didn't feel like it wanted to turn as well on sharp corners (going slow of course), but it didn't seem to hurt anything. its also kind of a cool feeling to go from rear wheel drive to front wheel drive, feels like you're getting pulled along.
'10 Wrangler Sport, soft top, hard doors, 23S package, Teraflex 2.5" spring lift, Spidertrax 1.5" wheel spacers
'79 CJ-7 Renegade, 258 I6, T150, D20, D30/AMC20, 2.5in Rancho lift, 31x10.5 AT's, TeamRush upgrade, flush tail lights - Sold :'(
Renegade79 is offline   Reply With Quote
Unread 01-06-2009, 03:57 PM   #10
jayhawkclint
1970 CJ5
You could just flat tow it if you are concerned. Do you have a pickup? HF has a $50 tow bar that works fine for CJs.
My '70 CJ5 Build Thread:
http://www.jeepforum.com/forum/f8/my...thread-359375/
jayhawkclint is offline   Reply With Quote
Unread 01-06-2009, 04:43 PM   #11
Joe_CJ5
1981 CJ5
See if anyone is in your area with a trailer, If i lived close id put it on my trailer and get it to a shop for yeah. Never hurts to ask for a helping hand.
Joe_CJ5 is offline   Reply With Quote
Unread 01-06-2009, 04:43 PM   #12
cbushrun
1981 CJ5
Thanks guys....I'll take er easy. early Sunday morning so I dont piss anyone off and see some "one fingered salutes!"
Unread 01-06-2009, 04:44 PM   #13
cbushrun
1981 CJ5
Thats a good point. I could always ask a neighbor....or make an excuse to the wife on why I need a double axle trailer vs a single like we have now.
I may be onto something........
Unread 01-06-2009, 04:57 PM   #14
Joe_CJ5
1981 CJ5
I have thought of selling my trailer a couple of times now , but something always seems to come up and I need it again. Now that I have the Jeep I am going to hang on to it.
Unread 01-06-2009, 06:12 PM   #15
jayhawkclint
1970 CJ5
x2. I treat my trailer like it's a part of my toolbox, as valuable as a torque wrench; not something that gets used everyday, but when the time comes that you need it, there usually isn't a way to finish the job without it.
