anything wrong with stock shackles? - JeepForum.com
post #1 of 11 Old 06-18-2009, 02:56 PM Thread Starter
blutowski
1978 CJ7
ive searched to no avail............ but theres a million different shackles out there. is there anything wrong with stock? i mean for street driving and some trails, some mud. no rocks. i get that you may want some custom stuff for real crawling. but for a guy like me would there be any drawback to just running stock ones? all i have is a 4" lift kit installed. and really i kinda wish that i didnt have that much lift. i know i want a stock length shackle anyways. if for some reason stock ones are a problem what stock length replacements would you suggest?
blutowski is offline
post #2 of 11 Old 06-18-2009, 03:49 PM
oteps
1980 CJ5
I dont know what jeep you have but I replaced mine on a 1980 cj5 with 1/4 inch steel and a piece across the two welded together. It seemed to handle better on the road but i replaced the bushings at the same time. stay with the stock length.
oteps is offline
post #3 of 11 Old 06-18-2009, 03:50 PM
fuzz401
1978 CJ7
I just replaced the bolts and run the factory side plates
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #4 of 11 Old 06-18-2009, 06:07 PM
gojeepin
1983 CJ7
It depends on how and where you're going to drive.
There's not a thing wrong with those shackles if they're in good shape and you've got bump stops to keep the springs from flattening too much. If you don't stop the springs before they flatten too much you can have trouble.
CJ leaf springs by the numbers...
about 48" = Length of most 4" lift leaf springs
45" = Length from spring mount eye to stock shackle fully extended
Just be careful and consider if you continue to flatten the spring beyond 45", the longest leaf could bend at its weakest point.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #5 of 11 Old 06-18-2009, 07:49 PM Thread Starter
blutowski
1978 CJ7
its a 71 cj5....... but i think the only thing that is 71 about it is the title. it will be 90 percent street driven. kind of a 4 wheel motorcycle. wanna hit a couple light trails just for the thrill of it. but for the most part just on the street. the only reason she has a lift is that i got a great deal on the frame and suspension. i woulda been happy with stock height. but the lift is growing on me. the suspension came with some lift shackles had made my caster angle terrible, so i think im gonna go back to some stock ones that i have. just wanted to know if there was some reason that guys change out thier stock ones for aftermarket. IE that the original set up is flawed in some way.
post #6 of 11 Old 06-18-2009, 08:21 PM
gojeepin
1983 CJ7
You shouldn't have a problem... I just gave you the numbers...
The big thing about caster is knowing what you have. Do you know what it is now? Do you know what it will be with the stock shackle?
BTW... My shackles are two inches longer than stock. My springs are 48.5" long or a little more than 4" longer than stock. Yes, it changed my caster but I fixed it.
gojeepin is offline
post #7 of 11 Old 06-18-2009, 09:39 PM
jeepskate
The spring info you gave does not apply across the board and doesn't apply to his Jeep. Pre-'76 springs are shorter and narrower...also there's plenty of 4" lift springs on the lower end of the price/quality scale that aren't 48"...you can pick them out easily when you see someone whith shackles that are near vertical or even past vertical in the wrong direction.
The advantages to the aftermarket shackles are that they're new (you're replacing older, possibly fatigued units), often have cross bracing which helps 'tighten up' some of the suspension slop/sway, and are made of thicker metal. Nothing wrong with the stockers if they're in good shape, but I always toss them when installing a lift.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #8 of 11 Old 06-18-2009, 10:00 PM
PERK
my question to you would be; Did you put the 4" lift on yourself. or buy the jeep that way? the plus of changing the shackles is that you would change out the spring eye bushings at the same time. for light trail/street use i would not go over 1/2 inch over stock,ConFerr used to make a good heavy shackle, see if there still out there.or look at the rubicon express ones, they don't cost that much.
PERK is offline
post #9 of 11 Old 06-19-2009, 10:16 AM
gojeepin
1983 CJ7
You're absolutely right about applicability to his model... I didn't read his model and based it on the '80s CJ7 in his profile... oops! You're also right about the length of 4" leaf springs in the lower price range and their particular attributes...
My main point with each post on this subject is...
1) know the working range of your spring mount to shackle (in inches)
2) know the length of your spring (in inches)
3) know how much the spring will extend as it travels upward
4) know your caster measurement (don't assume stock shackles are the cure all)
gojeepin is offline
post #10 of 11 Old 06-19-2009, 10:43 AM
JeepHammer
Running On Empty...
1973 CJ5
Some of the stock shackles are made with soft bolts and stamped steel brackets,
Other than that, there is much RIGHT with them!
Going to 'Lift' shackles, especially with 'Lift Springs' kills your dive line and steering component angles.
Makes the drive shafts enter your differentials at the wrong angle (drive line angle),
And lift shackles kill the 'Caster' angle on your steering axle.
This means your steering won't want to return to center like it's supposed to, and the vehicle will want to wonder around the road a lot.
Making some shackles out of thicker steel, but the stock length, and using some good Grade 8 Bolts with proper locking nuts is a good idea.
Going to 'Lift' shackles is a BAD idea.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #11 of 11 Old 06-19-2009, 11:18 AM
79-CJ-7
1979 CJ7
IIRC you want a little longer shackle when using a 4" lift spring. the longer shackles will allow the spring to flaten out. if the spring has no where to go i.e. when it is compressed it gets longer thus pushing the shackle forward, assuming that a shackle reveresal has not been done. A fattened spring is fine so long as you are not fighting the shackle, I mean if the shackle it to short and pushed all the way forward while compressing the spring the spring runs out of room to flatten out (grow)and all that energy will be taken up by the spring and if the spring wont absorbe this energy the spring will bend, thats why you need longer shackles.
Imagine if you will a flat spring, it has the ability to flex down of course but it will also flex up. this is very good for twisting (articulation). There are a lot of guys installed YJ springs on there CJ for this very reason. The YJ springs sit pretty flat when at rest. this allows the axle to move up and down.
Do a search you find all kinds of threads explaing the difference's.
TAKE A LOOK AT THIS
http://jeep.off-road.com/jeep/tech.s.../detail/260281
79-CJ-7 is offline
What Was The Stock Lenth On The Shackles jborkowski Jeep CJ Forum 1 02-13-2007 05:56 PM
stock shackles haustow Jeep CJ Forum 5 02-03-2006 04:32 PM
Size of stock shackles on a CJ7 capone1680 Jeep CJ Forum 4 01-05-2006 12:03 PM
Need stock rear shackles twmattox Jeep CJ Forum 2 02-08-2005 02:01 PM
need someone to measure their stock shackles for me on cj scottahicks Jeep CJ Forum 1 03-15-2002 10:49 PM
