Anyone swapped wider axles? - JeepForum.com
post #1 of 9 Old 01-26-2010, 05:27 PM Thread Starter
NotOfThisWorld
2006 KJ Liberty
Just like the title says...
Have you swapped out your stock axles for wider ones (TJ, JK, or other)?
How much wider were they?
Why did you?
Are you glad you did?
Blue Jeep Club Member #151
Arizona Jeep Club Founder
NotOfThisWorld is offline
post #2 of 9 Old 01-26-2010, 06:00 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Here ya go, Start reading
JeepForum.com - Search Results
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #3 of 9 Old 01-27-2010, 01:19 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
You can't link to a search like that. However, you can tell him what keywords you used in order to find some relevant threads.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #4 of 9 Old 01-27-2010, 02:07 PM
dhubing
I did. I went with a d44/12bolt from a 1975 K5.
How much wider - dont know the exact measurement before, but I am 82"(ish) front outside of tire to outside of tire.
Why did I - because I trashed my stock d30/amc20 and got a killer deal from a friend on complete axles.
Am I glad I did it - oh yes. Fullwidth is the way to go. So much more stability.
dhubing is offline
post #5 of 9 Old 01-27-2010, 06:01 PM
cyclic17
1981 CJ7
I swapped in a rear D44 from a Scout--very straightforward. Also swapped in a front D44 from a Wagoneer, and had to do more fabbing and ran into way more issues. Went from narrow trac CJ to about 58", so I gained quite a bit. I wanted more stability and strength, and I'm glad I did it.
*'81.5 CJ7, D300, T-5, 258ci, 4" BDS lift, 33 's on 15x10 Bajas, Narrowed Waggy D44 Front, Scout D44 rear w/ARB locker, Not-so-Painless Wiring Harness, Warn 8274, Borla Headers, MC2100 carb, Shrockworks sliders, KC's, Full cage
*RIP: '88 Comanche Chief, stock except for KC lights on rollbar and custom stereo.
cyclic17 is offline
post #6 of 9 Old 01-27-2010, 06:56 PM
timmayham
put on Currie 9" axles front and rear, went with TJ witdh from WMS to WMS (61 1/2"). Wider than stock (52"), gives the Jeep more stability and a much more agressive look, but retains one of things that makes a Jeep better than a fullsize to wheel... it's size. Expensive to go the custom axel route? Yes, but I got brand new assemblies with the gears and lockers of my choice, shipped right to my front door and bolted right onto the Jeep with no major issues.
timmayham is offline
post #7 of 9 Old 01-27-2010, 07:51 PM
2cjs
2cjs's Avatar
I went with a front d44 and rear d60.
not sure about the width.
did a spring over when I put these in.
it looks awsome.
I still have some work to do as well as getting my hi steer.
83 cj-7 258c.i., 727auto, d300, d44 front, d60 rear
92'yj 4.3(roller) tbi chevy,700r4 ,soa, 35-12.50-15 maxxis bighorns
89'yj wife's jeep 4.2l stock ,2"bl ,31-10.50-15 bfg mud terrains
work smarter not harder
2cjs is offline
post #8 of 9 Old 01-27-2010, 09:35 PM
foggybottombob
I have front and rear scout II dana 44's. The rear is 58" wms to wms and the front is close to the same but maybe 1 inch wider. I am working on a 60" wide dana 60 to swap in for the rear.
foggybottombob is offline
post #9 of 9 Old 01-27-2010, 10:58 PM
dr_hunt
1976 CJ7
I went ford 9 inch out of early bronco in the back, stock widetrack front with disc conversion from '85. It was narrowtrack, I like it better, more stable, stronger and easier to get parts for than the jeep. At least where I live as parts go anyway.
dr_hunt is offline
considering swapping in some wider axles . . .looking for opinions mcurcio1989 Jeep CJ Forum 0 11-05-2009 10:20 PM
Anyone that has swapped in wider D44's?? cyclic17 Jeep CJ Forum 8 11-01-2006 10:37 AM
Wider axles on 79 CJ5 COJAM Jeep CJ Forum 8 04-10-2006 10:11 PM
wider axles for cj7 jrod126 Jeep CJ Forum 35 09-20-2004 07:22 PM
Anyone swapped Scout II axles on a CJ-7? Brock Jeep CJ Forum 4 07-19-2002 02:55 PM
