Anyone Scratch Build All or Part of CJ Wiring Harness?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Anyone Scratch Build All or Part of CJ Wiring Harness??
Poison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!Free shipping on slip yoke eliminator kits New lower Price
Unread 07-05-2012, 06:16 PM   #1
turbonusse2
turbonusse2's Avatar
I was looking to redo some of the wireing in my jeep especially in the engine bay and the amount that I am looking to redo would mean all of the engine bay rewired and part of the in cab wiring. Is it possible to scratch build a wiring harness or would it be chaper to buy a new one. I understand the time that would go into a scratch built harness but i like making things exactly how I want them. any input is appriciated.
turbonusse2 is offline   Reply With Quote
Unread 07-05-2012, 06:36 PM   #2
keith460
Jeep. There's Only One
keith460's Avatar
If you do the Nutter Bypass or add a Weber carb, there is quite a bit of wiring that can be removed. It took me several days to eliminate the extra wiring that was no longer needed once the MCU was removed and a Weber carb was installed. Takes time to cut and splice wiring, solder the ends and using heat shrink to make it look professional. Plus, dedicated grounds will add some custom wiring along with relays for the headlight circuit.
I don't know if your wiring has been hacked to death by a PO and is the reason you are thinking that you need to start fresh, but I would try to save what you have if it isn't that bad. There are lots of special connections and lamp holders that are very hard to find in the aftermarket world.
First couple of pictures is what I started with and the bottom is the end result. Picture of the MCU and its wiring is what got removed and was no longer needed.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline   Reply With Quote
Unread 07-05-2012, 06:39 PM   #3
turbonusse2
Yeh the wiring is hacked up and many of the wires are too short to do anything with then just run them the shortest root
live and learn
Unread 07-05-2012, 06:40 PM   #4
turbonusse2
Is there somewhere I can just buy the engine side of the fuse box and male spade connectors and at least redo that part?
live and learn
Unread 07-05-2012, 06:46 PM   #5
keith460
keith460's Avatar
I saw an engine wiring harness for a 1984 CJ in the Classified section of this forum.
1984 CJ-7 Renegade
Unread 07-05-2012, 10:28 PM   #6
82JeepCJ7
1982 CJ7
I've basically done what you are suggesting on mine. I used the drawing done by John Strenk.
Since I went to a HEI distributor, I was able to eliminate almost all the excess wiring and now have just the bare bones needed to make it run.
I have since moved the starting solenoid up under the battery tray away from the exhaust manifold. My goal was to get the solenoid off the fender and eliminate about 6' of unneeded wire, as well as cleaning up the engine compartment.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline   Reply With Quote
Unread 07-06-2012, 03:14 AM   #7
John Strenk
John Strenk's Avatar
1976 CJ5
The only hard part is you have to buy many rolls of different colored wires. Trust me, you don't want to use one color wire in your whole harness.
You can get many of the terminals at NAPA. They are easy to pull out and replace.
Start here: http://www.jeepforum.com/forum/f8/ba...arted-1340134/
John Strenk is online now   Reply With Quote
Unread 07-06-2012, 06:15 AM   #8
82JeepCJ7
1982 CJ7
I was a helicopter avionics tech in the Army and we had a tool for marking wires that was basically a tool you put numbers or letters into and then they would get hot and you could then stamp the wire with a code. We would do that when replacing a wire in a harness on any given helicopter. Trust me, there is miles of wire inside a military helicopter, and they are all white.......
I wonder if you could find one that is surplus... I wish I could remember the nomenclature.
Unread 07-06-2012, 07:03 AM   #9
John Strenk
1976 CJ5
Like a "hot stamp wire marker"?
Unread 07-06-2012, 07:14 AM   #10
teh603
1963 CJ5
You sure you want the solenoid in an area where a battery leak could dump acid all over it? The only way I'd do it is to switch to a Mazda Miata battery that has the little vents and hoses that direct the aid down and out instead of into the compartment.
teh603 is offline   Reply With Quote
Unread 07-06-2012, 07:20 AM   #11
John Strenk
1976 CJ5
Ever price one of those batteries? I got one like that in my P...us and it's $180 to $220
That solenoid really doesn't look to much further away from the exhaust manifolds though.
Unread 07-06-2012, 09:14 AM   #12
hutch1200
Undocumented Pharmacist
hutch1200's Avatar
1979 CJ7
I have to move the solenoid the same way. Tilt nose is causing alot of "relocation" issues.
We will rest power from the people and will exert our military will over the masses with intent on restoring law and order. Doesn't sound right does it?
-.- .--- 7
hutch1200 is offline   Reply With Quote
Unread 07-06-2012, 09:37 AM   #13
82JeepCJ7
1982 CJ7
Yup, just like that.
The solenoid ended up about 10" away from the manifold. I do plan on building a heat shield between it and the manifold. I'm not worried about the battery leaking on it. That battery is in there just to get it going. I am replacing it with a Optima.
Unread 07-06-2012, 09:45 AM   #14
turbonusse2
Anyone know about how much those hot wire stamp maker things are?
live and learn
Unread 07-06-2012, 11:18 AM   #15
mminorhsd
1979 CJ7
The CJ7 I bought a couple of months ago to restore and have fun with, had no gauges that worked. I looked under the hood and saw a bunch of cut off wires just hanging around. One, by one I have rewired the gauges and have everything working except the fuel gauge. That one is next on the list. I looked are a wiring harness, but it was too expensive for me to consider.
Mike
1979 CJ 7, 258 cubic inch restoration project.
mminorhsd is offline   Reply With Quote
