Anyone running steps or rocker guards on a glass tub? - JeepForum.com
post #1 of 36 Old 07-22-2013, 07:31 AM Thread Starter
Jeeprage
Jeeprage's Avatar
I'm looking to add some sort of step to my CJ7 with 4wd fiberglass tub. My wife (and everyone else) complains that it is too hard to climb into as is.
I was considering an OEM style step, but not sure the floor would take that stress, and also considering rocker guards with a step rail off the side. Have any of you installed steps or guards on a glass tub successfully?
The other noteworthy detail is the 4wd tub also has a 1" body lift built in supposedly, and has a mounting plate between body mounts 2 and 3, which make lining up rockers difficult.
2015 JKU - 6m
Jeeprage is offline
post #2 of 36 Old 07-22-2013, 07:39 AM
HeathFinnie
1976 CJ5
I used to have tubes that you could step up on. Those bolted right onto the frame so there would be no issue with the glass.
HeathFinnie is offline
post #3 of 36 Old 07-22-2013, 07:42 AM Thread Starter
Jeeprage
Jeeprage's Avatar
I was looking to avoid "nerf bars". I would prefer functional-ish rockers, or OEM style steps. I don't want to lower clearance significantly if possible.
2015 JKU - 6m
Jeeprage is offline
post #4 of 36 Old 07-22-2013, 07:48 AM
HeathFinnie
1976 CJ5
Can't say as I blame you. Main reason why I don't have them anymore they look good sometimes, just not my personal preference or style.
post #5 of 36 Old 07-24-2013, 12:06 AM
Chewtoy
1976 CJ5
Just put these on mine. http://white-knuckleoffroad.com/jeepcj7.htm
Love them. The mount to the frame and are very strong. They also have an option for a 1" body lift.
With a great Jeep comes an empty wallet.
Chewtoy is offline
post #6 of 36 Old 07-24-2013, 02:43 AM
skizriz
1978 CJ7
I like Those. Price isnt too bad either.
Got any pictures of them mounted?
Sent from my HTC One SV using JeepForum
skizriz is offline
post #7 of 36 Old 07-24-2013, 06:48 AM Thread Starter
Jeeprage
Jeeprage's Avatar
Do you have a glass tub? Which one? Although they mount to the frame, 4wd's tub mounts differently and there is a plate between the 2 and 3 side mounts, which would obstruct this.
2015 JKU - 6m
Jeeprage is offline
post #8 of 36 Old 07-24-2013, 11:16 AM
j33pman
I've been running the AtoZ Fab rocker gaurds on mine, not on my fiberglass body yet, but will be within a a few weeks. http://www.atozfabrication.com/store...cat=249&page=1
Bill H. - 1984 CJ-7
Now with Fiberglass!
j33pman is offline
post #9 of 36 Old 07-24-2013, 11:21 AM Thread Starter
Jeeprage
Jeeprage's Avatar
Would you please follow up with pics and how you mounted them to the glass body? These are exactly what I want with the tube step. I'm hoping they'll clear the body mounts and that I'll be able to bolt to tub underside.
2015 JKU - 6m
Jeeprage is offline
post #10 of 36 Old 07-24-2013, 11:27 AM
j33pman
the bolts all go through the side of the body, none underneath, the rocker guard tucks under the body about 2 inches or so, so no issues interfering with the body mounts.
I will post pictures up when I get them mounted
Bill H. - 1984 CJ-7
j33pman is offline
post #11 of 36 Old 07-24-2013, 11:31 AM Thread Starter
Jeeprage
Jeeprage's Avatar
Thanks. The floor is thicker on the glass tubs though, so the part that tucks underneath could interfere with the floor height, not letting the rocker sit flush if too low. If too tall you could use spacers, but I doubt that is the case.
2015 JKU - 6m
Jeeprage is offline
post #12 of 36 Old 07-24-2013, 01:57 PM
Chewtoy
1976 CJ5
Nope, no glass tub. These mount to the frame, not the tub.
First pic is "Before", second pic is "After" and the rest just show how it mounts up. I am 5'7" and 225lbs and these things don't flex in the slightest with me using them as steps to get in and out.
As I understand it, tell Whiteknuckle you have a 1" body lift and they will move the sliders up an inch to cover the gap. They want the slider to sit 1/2 - 3/4 of an inch below the body.
2013-07-08 16.28.55.jpg   2013-07-18 13.05.41.jpg   2013-07-24 13.35.57.jpg   2013-07-24 13.36.14.jpg   2013-07-24 13.36.21.jpg
Chewtoy is offline
post #13 of 36 Old 10-08-2013, 07:29 AM Thread Starter
Jeeprage
Jeeprage's Avatar
Any updates from you guys? I'm not sure what will clear the 4wd Tub mounting plate when bolted to the frame. White Knuckle Offroad has one designed for a 1" body lift, which the 4wd tub has, but I think it will contact the 2/3 body mount plate.
2015 JKU - 6m
Jeeprage is offline
post #14 of 36 Old 10-08-2013, 07:35 AM
j33pman
Here is what my AtoZ Rocker guards look like on my fiberglass body
Bill H. - 1984 CJ-7
j33pman is offline
post #15 of 36 Old 10-08-2013, 07:45 AM Thread Starter
Jeeprage
Jeeprage's Avatar
What brand tub? Any pics of underneath how it ties to the frame?
2015 JKU - 6m
Jeeprage is offline
