Anyone run the Clifford 6 = 8 performance for the 258? - Page 3 - JeepForum.com
post #31 of 141 Old 10-13-2010, 07:09 PM Thread Starter
Lawless_Jeep
Originally Posted by oucheecrash View Post
I have a 250 in a 1963 chevy 2 with the clifford intake 390cfm holley dual exhaust and also one of their cams. I don't remember what the lift and duration is on it but all I know is that before I put my posi in it and 4:11 gears I was beaten in the 1/4 mile by a 5.9L dodge dakota by only 1 car length. Don't think that is bad for a little inline 6. The car has been on the road for 14 years and I have had no problems so far. Clifford makes a good product and I am looking into rebuilding my 258 with their parts this time too. Just remember to put the dual valve springs or they will break over time. I broke 2 over the years until I put the better springs in it.
That's a pretty great testament to a straight six!
Jeeps are sorta like cats, but tend to have more than just nine lives.
Lawless_Jeep is offline
post #32 of 141 Old 11-10-2010, 09:47 PM
TPSreports
1983 CJ7
I'm in the process of installing a Clifford header and intake on my 258 right now actually, can't wait to fire it back up.
After removing the stock exhaust and intake, I installed the new dual outlet header with no problem. It's the intake that I'm having trouble figuring out. Clifford told me to remove my centering pins and replace with 3/8 bolts or I will have a vacuum leak? When I tried to remove the pins with a vice grip, it seemed I would score the metal before turning the threads on the pins (I assume they are threaded)? This Jasper block has under 2k on it, so the pins shouldn't be seized.
Also, the header flange is much thinner than the intake flange. I had considered either building up washers, or welding steel stock onto the header flange. The guys Larry at Clifford advised against this. He told me to slide the 1/2" washer over to cover the header flange, and then put a 3/8" washer over the intake flange, and torque the header bolt, which I don't understand. I think my 3/8" washer has too large of an outside diameter to do this and I might need new hardware. Any others had this problem with the flanges?
1983 CJ-7 Laredo Jasper 258, Clifford intake/hedder, MC2100, HEI, MSD digital 6al. Warner T5, Dana 300, Dana 30/Ford 8.8 SOA, 33x12.50 Goodyear MTR
1999 XJ Cherokee Classic
2001 XJ Cherokee Limited
TPSreports is offline
post #33 of 141 Old 11-11-2010, 02:34 AM
birddogO1
1979 CJ7
I installed only the intake and exhaust manifold and the Holley 360 that Clifford recommended. I fabbed up a exhaust pipe out of stainless, ending with a Borla muffler. Not sure of the power gains, as I have bad rings in one of my cylinders, so I'am losing a lot of power down through the sump, I will be sorting this out over the winter. It certainly was a lot easier to tune and throttle response is very good, it also sounds fantastic.
They are good products, but require a bit of jiggery to install, as the guy above found out. I used washers of various sizes, including split locking washers, to tighten everything up. It was tricky, but no vacuam or exhaust leaks.
I can resist everything except temptation
birddogO1 is offline
post #34 of 141 Old 11-13-2010, 04:13 PM
cj5-9inchlift
1977 CJ7
will that intake fit if u have power brakes
cj5-9inchlift is offline
post #35 of 141 Old 11-24-2010, 12:28 PM
moparjeepster
1970 CJ5
Originally Posted by Ralphyar View Post
I just installed the Clifford on my 258, it runs great, the weak link is the gasket they give you, I have blown-out two in 700 miles. now I'm in the process of making my own. I found one site that would make the gasket out of 1/8" graphite composite, but the cost is $200.00 for 4 gaskets, that was mainly for the set-up charge. Any ideas out there
I used the fel-pro gasket set. It was like 16 or 18 dollars at Auto Zone.
1970 cj5 258, T18A, DANA300, AMC 20 3.73, DANA 30, TFI'd, mc2100, clifford single plane intake, clifford 6>2 headers, 2.25 dual flowmaster 40's
moparjeepster is offline
post #36 of 141 Old 11-24-2010, 05:03 PM
gmakra
Felpro X 2 the Clifford one that you soak in water for an hour is meant for racing and fails quickly.
gmakra is offline
post #37 of 141 Old 12-14-2010, 06:32 PM
TPSreports
1983 CJ7
Also, the header flange is much thinner than the intake flange. I had considered either building up washers, or welding steel stock onto the header flanges. The guys Larry at Clifford advised against this. He told me to slide the 1/2" washer over to cover the header flange, and then put a 3/8" washer over the intake flange, and torque the header bolt, which I don't understand. I think my 3/8" washer has too large of an outside diameter to do this and I might need new hardware. Any others had this problem with the flanges?
With some modification, both the header and intake now fit perfectly. I welded 1/4" square steel stock onto the header flanges after measuring the areas where there was a gap between header and intake flanges. Much happier with this than stacking up washers that will, of course, rattle loose.
Also had to shave the aluminum intake, just slightly, to get the header bolts in straight and have the intake fit properly. Happy with it, will post pictures soon.
All I need now is to buy some thicker washers (I'm thinking 1/2" circumference with a 3/8" internal diameter?) so that I can torque them both down properly and not leak vacuum. After that I'll fire it back up for the first time.
post #38 of 141 Old 12-17-2010, 11:57 AM Thread Starter
Lawless_Jeep
You'll have to let us know how the startup went. It's always exciting to get the Jeep back in motion.
At over two years on the road, it's still a thrill to hop in the Jeep everyday and just drive. Even though I still have the highway gear in, with the power the motor is producing, I do have to be careful when the roads are damp or icy. When the auto shifts, it can be a bit hairy unless I'm milking it.
post #39 of 141 Old 07-03-2011, 02:13 PM
stang-4
1982 CJ8
bump autozone sells the gaskets for the intake and header?
stang-4 is offline
post #40 of 141 Old 07-07-2011, 07:33 AM Thread Starter
Lawless_Jeep
I'm not sure if Autozone can order them or not, I know they can order a lot of items. It's not an item they keep in stock. I Usually order the Heddman gasket from either Summit or Jegs, for I've found those hold up really good.
post #41 of 141 Old 07-07-2011, 11:59 AM
walkerhoundvm
1981 CJ8
Buy the traditional intake/exhaust gasket. It may be in this thread or elsewhere, but the Clifford gaskets are junk, just like their intakes and manifolds. PM me for details on that part, but I put in a FelPro gasket for the header/manifold, used the Clifford gaskets for the header to collector, and 2 weeks later was kicking myself in the pants for doing that. Had to go to autozone to find collector gaskets because the Clifford ones turned to clay and cracked and fell out. Sounded cool, but having to redo that aspect with the headers ending up so close to the oil pan was not fun.
Bottom line: I would never purchase or recommend Clifford anything, ever.
walkerhoundvm is offline
post #42 of 141 Old 09-10-2013, 12:06 PM
fabin4130
Originally Posted by Lawless_Jeep View Post
Yeah, I was thinking that 360 ft pds sounded like quite a lot compared to the horsepower. I'm thinking that anything over the stock 115 horse is better than what I started with.
I've heard so much about the 4.0 head being better than the stock 258 head. When I bought the Jeep, I had larger valves installed and a little millwork. I think at this time, I'll keep the stock head and mess around with it a bit more before giving in to the 4.0 head. Just a little hot rodding in progress, and it's only money, right?
I've not heard anything about the dual outlet headers, so I'm a bit concerned that you say it can take away from the low end torque. I was planning to run a H-pipe just south of the headers. I'll need to do more research on my header choice now.
Thank you very much for the information.
I run a borla tri Y header 2 1/2 single out with a flow master 40 sounds super throaty!
fabin4130 is offline
post #43 of 141 Old 09-20-2013, 11:26 AM
fastkricket
1979 CJ5
I found a Clifford intake with a Weber 38/38 on Craigslist. What exhaust manifolds will work with that? Do I have to buy a Clifford? I'm trying to follow the KISS principle and go low bucks if I can.
fastkricket is offline
post #44 of 141 Old 09-20-2013, 01:52 PM
gmakra
No you will not need a Clifford header.
gmakra is offline
post #45 of 141 Old 09-20-2013, 02:15 PM
superj
I am running an offy with a 450 holley and stock exhaust on my i6. It will bark the tires pretty easily from a stop. I have an auto trans and the stock 3.55 or whatever gears.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
Clifford Performance Products? BBateman Jeep CJ Forum 2 06-26-2007 08:47 PM
Clifford Upgrade coxhaus Jeep CJ Forum 0 08-26-2006 03:15 PM
Clifford Performance? jadams68 Jeep CJ Forum 9 05-06-2005 06:17 PM
Clifford Performance MPI for 258 cmtierney Jeep CJ Forum 0 05-16-2004 06:08 PM
Clifford Performance... Guy Hollister Jeep CJ Forum 0 11-06-2001 03:15 PM
