anyone have the weber 38 dgev synchronous carb. do you like it? - JeepForum.com
post #1 of 20 Old 05-04-2010, 03:57 PM Thread Starter
vicker
is it worth the money over the 32/36 progressive carb? have a stock motor rite now but will add headers and a new ignition.
thnx for the feedback
vicker is offline
post #2 of 20 Old 05-04-2010, 04:16 PM
swatson454
1983 CJ7
There are several of us Weber 38 guys on this board and we're all very pleased with it.
If you'll search around on here, you'll find that 95% of the Weber problem threads are with the smaller, progressive Weber 32/36 and the Interco 34 where guys are having a heck of a time getting them to idle without turning the speed screw all the way in.
I highly recommend the 38!
Hope it helps.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #3 of 20 Old 05-04-2010, 05:55 PM Thread Starter
vicker
thanks for the reply. finally some solid feed back. i think i'll make my purchase tomorrow. carbs unlimited has the best price and 1/yr of tech support with the purchase. sounds good to me
vicker is offline
post #4 of 20 Old 05-04-2010, 06:52 PM
jeepsarecool
jeepsarecool's Avatar
1982 CJ7
I installed a weber 38 on my last CJ. As you can tell from my carb thread on the first page, I'm no expert. I put mine on and followed the instructions to tune it and it ran like a champ - HUGE improvement over the carter.
Check out my
CJ7 - God's gift to the masochist.
jeepsarecool is offline
post #5 of 20 Old 05-04-2010, 06:53 PM
swatson454
1983 CJ7
Carbs Unlimited is where I got mine. If you decide to go for it, and you'll be happy with yourself if you do, I would also advise the purchase of the upgraded, viton-tipped needle and seat, part number 1292.200.
You can avoid the additional costs and very potential headaches of the cheap fuel pressure regulators.
Most of the 38 guys haven't been around too much lately but if you'll search posts from TropicalNusselt, Felonious Monk, uptillnow, MonkeyHouse and CJ Chet, you should get a good idea of how pleased we all are with the 38.
Shawn
tuning Weber carburetors
post #6 of 20 Old 05-04-2010, 07:01 PM Thread Starter
vicker
im a bit of a noob. im not familiar with what a viton-tipped needle and seat is? redline makes a non adjustable fuel regulator that runs @ 2.5 to 3 lbs. i was gonna get that. would i still need the viton tipped needle and seat thingy sorry couldnt help it. lol
vicker is offline
post #7 of 20 Old 05-04-2010, 07:22 PM
swatson454
1983 CJ7
The viton-tipped needle and seat doesn't use the typical brass-on-brass contact that the stock one does. The stocker will basically pound out at the contact point as it flutters back and forth with each stroke of the fuel pump.
Obviously, the choice is yours. I just wanted to give you an option.
Here's the difference between the stock brass needle and the viton-tipped needle. Pretty easy to see why it's a better choice and I really wish Weber would just use the good ones.
Keep in mind that you'll probably need to make a minor adjustment in the float after the needle swap. Just measure the float drop before, like this...
and make sure it's the same with the new needle in place. Don't pay attention to my measurement, just set it back to the way that it came. Use the regular, bypass fuel filter with the return line positioned at the top and you'll be good to go as far as fuel pressure goes.
Shawn
weber carb tuning
post #8 of 20 Old 05-04-2010, 07:37 PM
rodjr
1980 CJ7
dont mean to hijack, but i was thinkin of using the 38 on my gm151 (i already know they absolutely rip on a built 151!) but i dont want to use a regulator, and i dont have a stock return line, just a 1 piece steel line from mech pump to carb. ya think itll b ok with the good needle/seat?
rodjr is offline
post #9 of 20 Old 05-04-2010, 09:02 PM
swatson454
1983 CJ7
I would say yes, unless it's a high flow/pressure fuel pump but I haven't tried it. I know the guys at Redline have only recently switched to the bypass filter to more closely resemble what we have so I can only assume that it will be fine.
Shawn
weber carb tuning
post #10 of 20 Old 05-04-2010, 09:39 PM
Fjguercio
1978 CJ7
I would recommend the 32/36 and 34/34 Webers far before the 38. The smaller carbs are used in the jeeps I6 at a ratio of 30-50 to 1. There are not that many running the 38s compaired to the smaller carbs.
Weber 34 and other progressive webers, they all work the same.
Here is the Weber Tune Link,
http://www.jeepforum.com/forum/f8/weber-34-dgec-carb-too-rich-jets-tune-jeep-4-2-258-a-631105/
Good luck,
Fred
Fjguercio is offline
post #11 of 20 Old 05-05-2010, 03:36 AM Thread Starter
vicker
thanks for all the replies. i think i'll still go with the 38 since i do want to do some engine mods in the future and this saves me having to rejet the carb anyways and really how much difference is there in mpg from the 38 compared to the the 34 or even the 32/36 progressive?
vicker is offline
post #12 of 20 Old 05-05-2010, 04:04 AM
kakai81
I went with the 32/36 progressive because of it's reliability and smoothness throughout the power band. Way better than the vaccum secondary that the PO had on it. I took my time adjusting it and dialed it in just right and it was a vast improvement. My brother bought the 38 at the same time and we tuned his the same day as mine. He had a flat spot in the high end, that took a bit of work to get rid of. Also he gets about 3-5 mpg less than I do, with no noticable power advantage. Both jeeps are "Team Rushed" and have new headers. My carb also cost less.
Just my opinion but I got the better deal. My brother thinks so too. He keeps trying to trade me because I like to fiddle with my jeep more than he does and I always tune his carb for him.
kakai81 is offline
post #13 of 20 Old 05-05-2010, 06:17 AM
LTEJ
1982 CJ7
I got the Webber 38, along with DUI, and hedders, and once I got the DUI right the webber tuned right up runs great now. I am not worried about the 2-3 MPG becuase my jeep is not a DD. It is just a toy, and as I was once told by a good friend, "You don't get gas mileage and performance in the same package, speed cost money, How fast do you want to go?"
LTEJ is offline
post #14 of 20 Old 05-05-2010, 09:18 AM
swatson454
1983 CJ7
I was half tempted to buy a 32/36 just to see what difference there was, definitely not to keep because the 38 is the better choice.
Come to think of it, I still might.
Shawn
weber carb tuning
post #15 of 20 Old 05-05-2010, 09:18 AM
Fjguercio
1978 CJ7
Weber 34 installed for over 2 yrs not and flawless.
I get 24 mpg hwy and the other day it came in at 25 mpg on a trip to get some parts. It pulls and roars from 600 to 4400 rpms. Many post on this forum or made contact in Twin Cities their 258 maxies out at 2800 rpms. I have a Weber 34, Summit CDI, TeamRush, Aux Grounds, Borla Header & Exhaust. I have been around jeeps since the early seventies and I have not seen a 258 run any better than this. For a stock engine internals.... this runs pretty darn well.
I can tune a idle from 450 to 900 rpms so I have adjustment on my idle screw.
A smaller range carb will always run smoother thru general operation situations. The only limitations would be WOT, wide open throttle, and most of us never run these 30 year old CJs WOT.
The Carter BBD can be corrected and modified to work just fine provided the linkage thru holes are not worn oval and just worn out. The Motorcraft 2100 and Weber 32/36 and 34/34 are all good alternatives. There are Holleys too. Lots of good choices!
Good CARB choices will give you 20 mpg+ hwy, decent power, and smooth operation where you want to run your CJ.
I think you will be happy with your 38 choice...... but keep in mind if you want any carb to be tweeked / matched to your engine... you will most likely be changing jets.
fuel pressure regulator , weber
weber 32/36 dgev junkyard war gimmesomerocks Jeep CJ Forum 8 03-13-2009 11:36 AM
Weber 32-36 DGEV conversion? 1Rustycj5 Jeep CJ Forum 1 02-08-2009 03:33 PM
Weber 32/26 DGEV jatepper Jeep CJ Forum 0 08-22-2008 04:25 PM
Weber 32/36 DGEV question onesourcemike Jeep CJ Forum 3 06-15-2008 10:57 AM
Weber 32/36 DGEV question CompGuru Jeep CJ Forum 35 03-07-2008 12:32 PM
