Anyone have pic of the howell map sensor placed - JeepForum.com
post #1 of 3 Old 04-23-2013, 07:23 PM Thread Starter
offroadz
1980 CJ7
Looking at how the sensor should be properly placed, as I believe mine is not.
Thanks for your help!
offroadz is offline
post #2 of 3 Old 04-24-2013, 01:16 PM
248107
Guest
1983 CJ7
right under the lip of the cowl about 12 inches away.Cowl lip is just wide enough you can bolt it there.That way the hose is short with no dips and higher than the TB
248107 is offline
post #3 of 3 Old 04-24-2013, 01:52 PM
RamblingCJ
I believe the hose shouldn't be any longer than 12", but I could be mistaken. However, it should be mounted with the hose pointing down. I zip tied mine to my main wiring behind the air assembly. You can see it in my pic.
RamblingCJ is offline
