Anyone have a part number for Offenhauser dual plane intake for 4.0 head (cast 7120)? - JeepForum.com
post #1 of 5 Old 11-22-2013, 01:34 PM Thread Starter
pityocamptes
I am getting my engine soon (stroker) and from everything I have been reading is that the Clifford 6=8 intake only produces more hp at higher rpm's, which are probably unattainable for the L6. It would seem, unless someone has a better thought, that the offenhauser 4bbl intake (dual plane) might be better for low rpm torque. Anyways, I have the part number for the clifford intake, but if anyone knows the part number or link to a Offenhauser intake for the 4.0 HO head (cast 7120), it would be appreciated. Thanks.
I looked on Summit racing and couldn't figure out if they had one that would fit the head...
pityocamptes is offline
post #2 of 5 Old 11-23-2013, 05:07 AM
gmakra
pity the head casting will make no difference with the exception of 0331 head which is 2000 + and has smaller intake and exhaust ports.
Here is the link to Summit http://www.summitracing.com/parts/ofy-6257dp/overview/
BTW the Offy and Clifford manifolds are made at the exact same foundry in Los Angles so they are the same quality which is good.
gmakra is offline
post #3 of 5 Old 11-25-2013, 08:36 AM Thread Starter
pityocamptes
Thanks! If you had to choose one, would you go with the offy dual plane, or clifford single? Its a stroked engine, with comp cam, and I was thinking of putting the truck avenger carb 470cfm... Thanks.
post #4 of 5 Old 11-25-2013, 09:56 AM
swatson454
1983 CJ7
To be honest, I don't see a single thing about the Offy that's "right". My personal opinion would be the Clifford with a 4-hole tapered spacer. That will slow the air down and give it some direction before dumping it into the plenum. It would probably help on the Offy too but I don't see how in the world you can keep the fuel from crashing into the floor on the primary plenum.
There are cheaper tapered spacers out there but that is a good pic to illustrate the difference between it and a regular spacer.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #5 of 5 Old 11-25-2013, 11:30 AM
gosupes
Shawn
One of the issues with running a spacer is clearance between the carb and brake booster, depending on the carb type and booster type/size of course. Found out the hard way.
To be honest, I have heard the same thing about the dual plane, that they are better for low end, and I really cannot make an apples to apples comparison, but I don't think I am suffering from lack of low end torque with the Clifford intake. If I was building a stroker, first choice would be FI, but I would not have any qualms about using a Clifford and good carb.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
