Anyone have a 72-75 cj5? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Anyone have a 72-75 cj5?
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 11-24-2014, 09:16 AM   #1
deezil
I need to get a dimension from the front of the frame horns to the center of the front stationary spring hanger. The one under your feet on the front suspension.
I have a 1973 cj5 frame that has been modded out and has had all the suspension mounting pint taken off and all the rivet holes welded up. I want to return the frame to stock but I do not know where the front spring hangers stationary spring hangers need to be placed.
If some one has a 72-75 cj5 can you please get me the dimension from the front of the frame horn to the middle of the front spring hanger eye?
I would appreciate it greatly.
deezil is offline   Reply With Quote Quick reply to this message
Unread 11-24-2014, 11:03 AM   #2
CSP
#10 in this drawing
CSP is offline   Reply With Quote Quick reply to this message
Unread 11-24-2014, 04:32 PM   #3
roadhog304
1973 CJ5
Not trying to hijack the thread but do you have one of those diagrams for a 76cj7 CSP?
1973 Jeep CJ5 Amc powered resto-mod
1976 Jeep CJ7 GM powered future 1 ton crawler
roadhog304 is offline   Reply With Quote Quick reply to this message
Unread 11-24-2014, 05:06 PM   #4
CSP
That diagram was found via google images. Anyone can do it. (hint)
Unread 11-24-2014, 05:28 PM   #5
Fourtrail
1974 CJ6
That would be #9 in the drawing, not #10. #10 is shackle mount center to spring mount center. #9 is frame horn to spring mount center.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline   Reply With Quote Quick reply to this message
Unread 11-24-2014, 06:18 PM   #6
roadhog304
1973 CJ5
A simple " I got it off google" would have been fine. You really don't have to be a d--- all of the time or is that just your nature?
Unread 11-24-2014, 08:20 PM   #7
CSP
You're right on both accounts roadhog. It wasn't intended to be a d!ckish comment but I can see it being that way. Thanks for pointing that out and you have my apologies.
