Anyone got pics of parking brake cable routing? - JeepForum.com
post #1 of 17 Old 02-14-2011, 10:57 PM Thread Starter
Mickey_D
I just picked up a 55 CJ-5 and there seems to be a few parts missing from the parking brake assembly.
The handle is there and the cable attached to it. But it ends at the turnbuckle right under the driver's seat. I don't even see a way for cables to get through the backing plates on the rear drums.
Also, does anyone know of a trick to getting the drums off? I got all three of the flat head slot screws out, but the drums feel like they are part of the axle shaft. I know they aren't, but they don't move at all. Even with a little persuasion from a BFH.
I appreciate any and all help.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #2 of 17 Old 02-15-2011, 07:35 PM Thread Starter
Mickey_D
Anyone?
________________
#4
Mickey_D is offline
post #3 of 17 Old 02-15-2011, 08:13 PM
Alby63
1982 CJ5
Weren't the parking brakes on those located on the back of the transfercase?
'82 CJ5, glass body, 327, Holley Stealthram Pro 950 EFI, B&M Turbo350, Dana 44/30, Lockers, 3.73's, 6-1/2" lift, 35's, stainless mustang SLP exhaust
Alby63 is offline
post #4 of 17 Old 02-15-2011, 08:45 PM Thread Starter
Mickey_D
Not that I know of. I know my brother's '65 Land Rover has one like that. I had seriously thought about fabbing one up on the rear of the transfer case, but without a half shaft it's next to impossible.
________________
#4
Mickey_D is offline
post #5 of 17 Old 02-15-2011, 10:56 PM
greengiant1
1947 CJ2A
The park brake was definately on the back of the transfer case. That turn buckle on your cable would have attached to the operating lever for the park brake.
greengiant1 is offline
post #6 of 17 Old 02-15-2011, 11:00 PM
greengiant1
1947 CJ2A
Go to Morris 4x4. Look brake parts. There you will see a 3 leg puller used to pull the rear brake hubs off the axles. Rental yards used to rent them 30 years ago. Today ???
post #7 of 17 Old 02-16-2011, 08:36 AM
Rick7
Here is the setup-- the cable attached to the crossmember and the clevis operated the parking brake lever in the picture.
Rick7 is offline
post #8 of 17 Old 02-16-2011, 06:45 PM Thread Starter
Mickey_D
If that's the case, then someone went to a LOT of trouble to remove ALL of the e-brake components from my Jeep.
Edited to add a better pic.
________________
#4
Mickey_D is offline
post #9 of 17 Old 02-16-2011, 07:23 PM
chromegrille
1947 CJ2A
no trouble at all.
just remove the brake drum and backing plate assy.
bolt the driveshaft back up
easy and done all the time
chromegrille is offline
post #10 of 17 Old 02-16-2011, 07:33 PM Thread Starter
Mickey_D
Except if you look in the diagram in post #7 everything goes BEHIND the output shaft yoke. So that would have to come out of the transfer case to get the drum and backing plate off, then be put back in the transfer case.
The only thing I can think of is someone put a twin stick transfer case in (same shifting pattern as the original dash plaque shows) to replace the original. And the replacement didn't have an e-brake on it. Just seems weird that the transfer case and the transmission have the same layers of grime on them...
________________
#4
Mickey_D is offline
post #11 of 17 Old 02-16-2011, 07:37 PM
chromegrille
1947 CJ2A
still no trouble, slide the yoke off.
I was assuming that was obvious.
It's not rocket surgery.
post #12 of 17 Old 02-16-2011, 07:47 PM Thread Starter
Mickey_D
Sorry, I looked at another (more detailed) diagram and realized the yoke only bolts onto the output shaft. I thought the yoke WAS the output shaft.
Ok, so now it's just a matter of finding all of the parts to make an e-brake out of (backing plate, shoes, drum, etc. I can get the shoes locally and the drum from Morris. But the backing plate is proving to be a little more difficult to locate.
________________
#4
Mickey_D is offline
post #13 of 17 Old 02-16-2011, 07:51 PM
Matt_G
1979 CJ5
looks to me like it simply bolts to the output yoke inbetween it and the driveshaft
"This isn't mud, it's a special Jeep Wax"
Matt_G is offline
post #14 of 17 Old 02-16-2011, 09:26 PM
Alby63
1982 CJ5
http://cgi.ebay.com/ebaymotors/willy...item2561323d8b
Alby63 is offline
post #15 of 17 Old 02-16-2011, 10:49 PM Thread Starter
Mickey_D
Dude, not even an hour ago I searched ebay for that stuff and found NOTHING!
Thank you, thank you, thank you!!
________________
#4
Mickey_D is offline
cj3a brake cable routing randya Jeep CJ Forum 0 01-30-2011 04:19 PM
CJ Parking Brake Cable Woes ardis8500 Jeep CJ Forum 7 03-26-2010 08:24 AM
Parking brake cable length with wide Amc-20 ziv Jeep CJ Forum 4 10-06-2009 02:18 PM
Speedometer Cable Routing (HELP) jpnkavu Jeep CJ Forum 2 12-28-2006 12:21 PM
how do I install new Parking brake cable for my CJ Spencer77 Jeep CJ Forum 1 12-22-2005 06:09 PM
