Anybody running 33s with a 2.5 Lift - JeepForum.com
post #1 of 7 Old 02-02-2013, 10:15 PM Thread Starter
ridge28
1964 CJ5
I have a 2.5 inch skyjacker lift on my 64, i ahve a lot of extra room with my 31s and am looking at tires, are 33s a legitimate option? anybody else have this set up? Pictures?
ridge28 is offline
post #2 of 7 Old 02-03-2013, 08:56 AM
CJ51973
CJ51973's Avatar
I ran them on my 73 with 2 1/2" lift. Fender trimming (pretty big) was needed if you are offroading it. If you are just driving it on the road or mud bogging it might be possible to make some really long bump stops. CHeck out my pictures as there should be some of my 73 on there. That said, I think 4" of lift is too much for a narrow track CJ5. I was happy with the results although if I did it again I would try to make something better looking with some TJ flares.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #3 of 7 Old 02-03-2013, 09:25 AM
agear
I have a 2.5 suspension lift with a 1 inch body lift on my 84 cj7
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #4 of 7 Old 02-03-2013, 02:34 PM
my_304_cj7
1976 CJ7
I was running 33" DuraTracs with 2.5" superlift. I didn't like the look though so I went with a 1" body lift. I drove it for a year before the body lift.
'76 CJ7 Quadra-Trac 304 2.5" superlift 1" body lift 33" DuraTrac's
2014 Grand Cherokee Altitude
my_304_cj7 is offline
post #5 of 7 Old 02-03-2013, 02:38 PM
my_304_cj7
1976 CJ7
One other consideration, 2.5" is just an approximate based on vehicle weight. If CJ-7's and 5's use the same springs I don't see a company manufacturing two different spring rates for each vehicle considering the low volume of orders they probably receive. The 5 being lighter, you may get more than 2.5".
*After a little research the springs are the same, so that would be something to consider.
post #6 of 7 Old 02-03-2013, 02:43 PM Thread Starter
ridge28
1964 CJ5
So would 32s be more reasonable?
ridge28 is offline
post #7 of 7 Old 02-03-2013, 05:50 PM
74Maverick
I ran 33x14s on 2.5 BDS no problem on my old 7, now same springs and tires on my cj5 with a lil shackle(3/4 in) and no problem. Also my roomate stole some of my 33x14s and put em on his stock(i think it may have an inch or less body lift) cj7 and he has only minor rubbing during flex.
The Last Great American Hero... the demi-god... to which speed means freedom of the soul.
74Maverick is offline
